cyber8888 cyber8888 is offline
Car: 2015 BMW 228 M Sports
Default Cranked up JB+ to 4 psi .. is that safe for N20? - 05-13-2018, 01:58 PM
Hi. Just got JB+. After using the 3.5 psi default setting for 2 days, I cranked it up to 4 psi.
I read somewhere that 3.5 psi is recommended for N54/N55 engines but N20/N26 engines will be fine at 4.0 psi. My engine is N20, and I always use 93 Octane. So far, it seems to run fine with no Cels and no knocking.
I also read that N20 stock does 17 psi, and so with the 4 psi boost, that takes it up to 21 psi. Whats the limit for N20s ?
I put Stabil 360 due to 10% ethanol. I was wondering if I still need Octane booster in addition to using Octane 93 top tier gas. Thanks.
Default 05-13-2018, 09:49 PM
It's hard to tell with only a Jb+ but as long as there's no sputtering and the car is strong, keep at it. Make sure to fill with 93 as you stated and you'll be fine.
Default 05-14-2018, 05:59 PM
Thanks. I hope so. How much PSI boost can the N20 engine take? Do you know? Thanks
Default 05-14-2018, 08:35 PM
It's honestly relative but with a JB+ I wouldn't even worry about it.
Default 05-15-2018, 07:56 AM
Ok Thanks for your comments.
Anyone else here running JB+ on max 4 psi for several months now ? Thanks,
Default 05-16-2018, 03:35 AM
Do i need to upgrade my chargepipe ?
Default 05-16-2018, 07:38 AM
Only if it breaks, I doubt you'd need to.
Default 05-17-2018, 06:11 PM
Thanks. Makes me feel better about using JB+
