(#276)
rygre rygre is offline
Car: 2016 340i
Default 08-05-2018, 08:45 PM
Originally Posted by onfire
Killer times pure stock ! BG is a good track. Around 446ft msl. At 6:30 pm it should “ballpark “ around 2800ft.DA.
It's a great track and those numbers are probably pretty accurate, I guessed about 2500. Yes I was very impressed and satisfied to get that 10.9 all stock everything!!
2018 M5 | Bone Stock
2016 340ix | M-sport | JB4 | ER D@wnpipe | BMS Intake
Default 08-05-2018, 09:56 PM
Temps in the low 70s. Still stuck in the 10.8 range but a little quicker. It launched so far it gave a "warning: damage to vehicle" warning on the center console as if it had been in a collision lol. 3.2s 0-60. AFR got in to the low 11s in 5th.
onfire onfire is offline
Car: X5 50i F15
Default 08-06-2018, 04:35 AM
Originally Posted by rygre
About 2500
I bet you hurt some feelings at the track with those number !
Car: X5 50i F15
Default 08-06-2018, 04:38 AM
The 1.72 sixty is holding you back. Launch procedure ?
Car: X5 50i F15
Default 08-06-2018, 04:53 AM
That big mph is showing the big HP JB4 can make.
Car: 2016 340i
Default 08-06-2018, 05:07 AM
I found using launch control is more consistent but is actually a little slower. Without it I could cut 1.63/64 and run a 7.0x 1/8th but I also had to worry about the breaks pushing through and red lighting. I would guess Terry is trying to launch consistent and has a technique he sticks to.
Car: X5 50i F15
Default 08-06-2018, 05:42 AM
LC is an easy 1.68 1.63 is impressive by foot brake boosting. Did you LC the 10.99 pass ?
Bushidopupil's Avatar
Bushidopupil Bushidopupil is offline
Car: 2011 CTS-V Coupe
Default 08-06-2018, 06:31 AM
About 2500
Great! Thanks.
F01Boost F01Boost is offline
Car: 750I
Default 08-06-2018, 06:47 AM
Yes looks really Promising. Low 10s coming soon!
2018 BMW F90 M5 - Dme Stage 2 D/P & mid pipe
2014 BMW 650 dme tune - Gone
2012 BMW 750i M Sport - JB Beta - Gone
2011 BMW 135 - JB tuned - Gone
2008 BMW 535i - Jb tuned - Gone
Default 08-06-2018, 08:42 AM
I just brake boost it. Might be able to launch it a bit harder but I'm more or less launching it as hard as it will go. Never been able to engage launch control and doesn't seem I need to. I suspect it requires DTC fully disabled like it does on other models which I'd rather not do racing.
Car: X5 50i F15
Default 08-06-2018, 08:50 AM
If you want to keep DTC activated, part throttle brake boosting is the best method. Do a couple of hard stops before making a run....helps the front pads clamp.
Default 08-06-2018, 09:42 AM
I kinda expected a bit higher trap with the racegas, I guess AFR is so damn rich though.
Default 08-06-2018, 09:48 AM
Timing wasn't that bad previously so I did not expect a ton out of the race gas. It might take more boost and cooler weather to get the traps up. It's definitely a heavy car though. When it cools down a bit we need to get all the new cars over to Famoso for some test and tune action!
I think realistically on a cool night 10.6@134mph on race gas and map3 tune only is a plausible goal. And for a basically stock car, would be pretty sweet.
Default 08-06-2018, 11:41 AM
Why don't we rent it out for one night a small group of OUR people only. Plus I can have my cousins drive up some BMS cars so we can actually test them all
Default 08-06-2018, 12:03 PM
Maybe when it cools down. But with dragy now it's so easy to get metrics, hardly worth the extra effort for a big drag day anymore IMHO.
Car: X5 50i F15
Default 08-06-2018, 12:32 PM
When I am logging “Boost” with JB4, which sensor is it recording?
Default 08-06-2018, 02:13 PM
Boost is driver side boost, and boost2 is passenger side boost.
Default 08-06-2018, 02:59 PM
You live near farmland so you have long stretches of roads. I don't have that luxury
Car: X5 50i F15
Default 08-15-2018, 05:31 AM
Is 50% on the Throttle Log equivalent to. 100% open with the valvetronic system ?
Default 08-15-2018, 07:40 AM
The throttle body is over sized for flow and used to as a safety system for valvetronic which does the majority of the engine control. As mapped will move around from 50-100% depending on where boost is vs. boost target, and engine speed.
Car: X5 50i F15
Default 08-15-2018, 07:46 AM
Is the left side JB4 scale that goes from 0 to 50 a double value to get to the “50-100%” range ? IE , if the “Throttle “ log is at 45% on the JB4 scale, multiply that by 2 for an actual 90% ?
Default 08-15-2018, 08:28 AM
It's saved as 0-100% in the CSV, and shown as bottom to top when looking at chart.
Car: X5 50i F15
Default 08-15-2018, 09:26 AM
So a chart “30” is 80% open ?
Default 08-15-2018, 10:34 AM
If Y scaling is set to 50 (default) then 30 is 60%.
Car: X5 50i F15
Default 08-15-2018, 10:56 AM
Thanks !
