Q50JB4SS Q50JB4SS is offline
Car: 2018 Infiniti Q50 SS
Default 2018 Q50 SS CSV file for interpretation - 05-18-2020, 05:10 AM
Good morning. If possible, can you please look at the attached CSV file. Wanting to make sure everything is in working order before I try out map 2.
2018 q50 SS
93 octane
LDP
Default 05-18-2020, 05:10 AM
Fuel wires also installed and activated.
Default 05-19-2020, 03:12 PM
Looks good to me. Map2 and map3 should be fine!
Default Map2 - 05-21-2020, 07:19 AM
Good morning,
Map2 runs (x2 runs) are attached. Will try map3 today. Even though I'm at Map2, the initial Target psi was 4 then increased to 5. Is that normal? Just want to make sense of the data. My goal is for custom map6. Thank you.
Default Map3 - 05-21-2020, 12:56 PM
Map3 attached. Please let me know what you think. My goal is to run map6. Not looking for maxing out the engine, just some power when needed. Thank you.
Default 05-21-2020, 04:52 PM
Map3 looks fine. Map6 can be setup to be more conservative than map1 or more aggressive than map7, it's usually used for people who are in to reading their logs and want to customize the profile with more boost taper or for some specific reason.
Default 05-21-2020, 07:19 PM
So from the different maps I've logged, which one do you recommend as having the best results?
Default 05-21-2020, 08:17 PM
Map3 seems like a good fit to me, but always up to you.
Default 06-12-2020, 11:03 AM
Just did 2 more runs on map3. 1st from a dig and second from a roll. My plan is to move up to map 4 then map 5. Please let me know if there numbers look good for me to advance. Thank you.
