Cretosx Cretosx is offline
Car: 335i N54
Default Yet another misfire - 09-13-2019, 03:45 PM
Hi
Just upgraded my car to hybrid turbos and fbo and constantly having cylinder 1 misfire on jb4 bef and map 1 I've used the hybrid guide already, replaced plugs and coils and all 6 injectors and walnut blasted 8k ago
THE BEAST's Avatar
Car: 2008 E93
Default 09-13-2019, 04:48 PM
Originally Posted by Cretosx
Hi
Bank 1 02 sensor?
throwing any codes ?
Car: 335i N54
Default 09-14-2019, 12:45 AM
Bank 1 02 sensor?
No codes
HKD126 HKD126 is offline
Car: 2014 335i
Default 09-14-2019, 03:41 AM
Vanos?
Default 09-15-2019, 10:00 AM
Looks like your stuck in open loop (trims stuck @ 25) & your bank 1 AFR looks off- looks like an o2 sensor issue
Car: 335i N54
Default 09-16-2019, 07:38 AM
Replacing both 02 sensors for good measure and will produce new logs afterwards
thank you.
Default 09-16-2019, 12:43 PM
thank you.
Never a bad idea, especially if they've never been replaced.
