Durbzman Durbzman is offline
Default Take a look at my logs please - 09-13-2019, 02:10 PM
Hi All, new to this forum but would really appreciate some help looking at these data logs.
Please let me know if I’ve done anything incorrect in the logging I’ve not done this before.
The car is throwing an ECL and also knocking off the JB4.
Car is N54 335I , down *****, *****, OCC, 3.5 Bar Tmap, MHD stage 2 Flash 98 Ron, JB4,16.5T Chinese turbos
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 09-13-2019, 02:25 PM
You have fuel problem. Your lpfp and hpfp numbers dip under boost.
08 E90 335i
Montego Blue
JB4/MHD E85 BEF
BMS DCI
BMS OCC
BMS Cowl Filters
VRSF ⬇️ Pís
MMP Chargepipe
TIAL BOV
BMS Pedal Tuner
BMS PCV VALVE
NGK 97506 @ .022
STAGE 2 LPFP
H&R Springs
19' 666m Wheels
Milehighbmw Milehighbmw is offline
Car: 07 335xi
Default 09-13-2019, 07:39 PM
I don't know if it's appropriate to ask this in someone elses thread but I'm trying to learn. If so I apologize in advance. Why are his boost #s jumping so high above target?
Car: 2008 E93
Default 09-13-2019, 08:04 PM
Start off in map 1. You are boosting into 30s psi . You missed fud =6
What fuel ?
Edit...NVM, I see fuel in your signature. If you love your motor, lower boost asap.
Default 09-14-2019, 12:38 AM
Ive been advised that the AFR is above 12 and ideally it needs to be below 12, Iíve also been advised that If I was running this lean that meth would help to bring down the AFR?
Default 09-15-2019, 10:02 AM
Your way way overboosting...to the point it’s not safe.
Lower your boost safety to 20-21 to start & relog map 1
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
