yandy2005 yandy2005 is offline
Car: 2014 BMW M5
Unhappy BMW M5 F10 with pure turbos stage 1 only 540whp - 04-03-2019, 09:24 PM
Good evening guys, sorry if i am posting this in the wrong place, having a hard time making power on my 2014 M5, any help or inputs would be appreciated.
Trying to figure out what seems to be the issue with my car.
Put the car on the dyno before BM3 tune and it made 532WHP and 550 or torque car had ********* at this point and no tune, after this my turbos went bad and i had Pure turbo rebuild them so my turbos are pure stage one. Did the BM3 stage two tune and the car made 572WHP at the same dyno and 659 of torque, after that i send the maps to Halim and he said my iAT where to high at the dyno, i am in south Florida so it is hot down here, So try it his beta stage two map and the car made 545whp and like 550 of torque, after this i replaced my intake filters, did the thermostat 90 degrees upgrade and change my coolant too to the BMW oem one. I had sent logs to Halim from BM3 after that and he says everything looks good that the car won't make any more power.
Took the car to active autowerke, compression on all cylinders is between 195 and 205, so they said is good, smoke test was good too, not sure where else to look anymore, they said my spark plug look orange, help me out let me know what do you think Terri?
bootmod3 - 5c943eadae729b04494841c7 datalog chart
bootmod3 - null datalog chart
Default 04-04-2019, 08:24 AM
Need JB4 datalogs to evaluate.
Sounds like you're not making boost or maybe just a low reading dyno?
Car: 2014 BMW M5
Default 04-04-2019, 03:07 PM
this was on a dynoyet and it is tune with bootmod3 not jb4.
Default 04-05-2019, 08:38 AM
What are boost levels at?
Car: 2014 BMW M5
Default 04-05-2019, 08:45 AM
22 pounds of boost, and it is hitting boost target on the logs.
garyf10m5 garyf10m5 is offline
Car: F10 M5 CP
Default 04-11-2019, 01:12 AM
Sorry to probe, i also did the 90c thermostat upgrade bought from ECS tuning but my dme kept coming out with a code named "1D2404 Map thermostat, line disconnected" after installing it.
Also, i checked and the wire harness to the thermostat is connected and not loose. Does yours have this issue? Though i felt that my fan kicked in earlier and temps are slightly lower now. Sorry to sidetrack and i appreciate your reply.
Car: 2014 BMW M5
Default 04-11-2019, 10:41 AM
Mine did not give me any errors at all, but i did not do the install a BMW master tech did it, but i have not really seen any improvement over this mod.
Car: 335i, 2009
Default 04-11-2019, 11:33 AM
I did the thermostat update and the car does report a significantly lower coolant temp. Also, post a g*d damn JB4 log already. Nobody is going to be able to help with it. Doctor can't diagnose what disease you have without a checkup.. well the JB4 log is part of your checkup.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Car: 2014 BMW M5
Default 04-11-2019, 11:54 AM
Look i just came here for advice, as i put on my description i have bootmod3 not JB4, now you need to relax because i have not disrespected anyone here so don't talk to me like i am a f idiot. I have done plenty of logs with Halim the tuner, i was just looking for some extra help here.
I i was replying to garyf10m5
Car: 335i, 2009
Default 04-12-2019, 09:52 AM
Sorry, my bad, Just assumed. All the same, you will get the best support from people who offer that tune. Each tune from different providers are a little different anyways.
BMS Stage 1
335xiboost's Avatar
335xiboost 335xiboost is offline
Car: 2008 335xi jb+ VSRF ******* DP DCI cabin filter delete
Default 04-16-2019, 06:07 PM
Check AFR $100 says youíre lean
2014 M5 1 of 577 6spd awaiting MORE BOOST
07 Cayman 5sp
08 Cayman S 6spd
02 996 TT 6spd more boossttt
04 Gallardo gated 6spd
335xiboost's Avatar
Default 04-16-2019, 06:09 PM
Iím lean with meth at 22psi and trying to figure out why. Going to try 100 or 116 octane tomorrow and get rid of boost juice for 100% meth. New colder plugs and new coils too. Sounds like if youíre making the boost and not the power youíre leaning out and timing is adjusting for that.
07 Cayman 5sp
08 Cayman S 6spd
BMRDude BMRDude is offline
Car: 2012 550ix
Default 04-24-2019, 03:16 PM
Yandy, are you running ********* or do you still have cats?
if you still have the cats, have someone scope them through the O2 sensor fitting to see if they are partially plugged.
you noted you had orange plugs. the orange can be caused by octane booster additive (MMT) which can plug cats with manganese oxide and sulphate.
