goonw goonw is offline
Car: i30N
Default Map 2 Log Check - 03-18-2020, 02:46 AM
Hi, just installed JB4 in my i30N NPP, stock, and on 93 fuel. Not sure if I installed the fuel wire correctly.
I've attached 2 logs; 1 on normal driving mode and the other on N driving mode. Please let me know if there are any issues!
Default 03-18-2020, 10:06 AM
Raise boost safety to 26 psi and get another log on map 2 please.
Car: i30N
Default 03-18-2020, 10:18 AM
Thanks Payam for the response. Please guide me on how to raise boost safety to 26 PSI. I'm still concerned about the fuel wire. Are there any indications that something is not in order?
Default 03-18-2020, 10:26 AM
Right now you're getting kicked into map 0 safety, so the car is stock.
Connect to the car while it's on with JB4 mobile. Go to settings>user adjustments> you'll see boost safety, change the value to 26 and click save on the bottom.
Get another log on map 1 or 2 so we can see what's going on.
Car: i30N
Default 03-18-2020, 10:35 AM
Thank you for the instructions! I'll have to assume you mean to change "Boost Failsafe PSI" to 26 after selecting either Map 1 or 2, as I'm not connected to the JB4 right now.
Default 03-18-2020, 10:37 AM
Yes, correct.
Car: i30N
Default 03-21-2020, 02:02 PM
There you go.
Default 03-23-2020, 10:27 AM
There you go.
Looks nice a strong here!! How does the car feel now?
Car: i30N
Default 03-23-2020, 10:37 AM
Thank you so much! Need to get to a better location once this virus thing settles down. Still kinda apprehensive about installing the BMSWMI which is under my bed right now; many things from the install guide I cannot fully understand.
Default 03-23-2020, 11:29 AM
Post up some questions and I'll do my best to clear them up!
