baggy999's Avatar
baggy999 baggy999 is offline
Car: Q50 3.0T
Default Newbie Log Review - 11-29-2019, 11:12 AM
Hi All,
I just received my JB4 and did a couple of runs on Map 1, with 93 octane and no other mods installed except the JB4. Please let me know if they look good or not.
Thanks,
baggy
2016 Q50 3.0T Luxe RWD
JB4
Default 11-30-2019, 10:19 AM
Looks fine to me!
baggy999's Avatar
Car: Q50 3.0T
Default Log Review - 11-30-2019, 11:54 AM
Thanks for the review and feedback! I'll step it up to Map 2 and repost.
Cheers!
Baggy
JB4
baggy999's Avatar
Car: Q50 3.0T
Default 12-02-2019, 09:45 AM
Attached are a couple of runs with Map 2 loaded. Let me know if this is good to go.
Cheers!
Baggy
JB4
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 12-02-2019, 11:01 AM
Cheers!
Baggy
JB4
Looked ok to me. Max boost of about 15-16 psi, timing held nice and raised at the end, afr was in check.
2016 Q50 Premium 3.0t AWD
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
baggy999's Avatar
Car: Q50 3.0T
Default 12-02-2019, 04:48 PM
Thanks for the feedback!
Do these logs looks ok for me to try map 3?
Cheers
Baggy
JB4
Default 12-03-2019, 03:23 PM
I would skip straight to map 5 or create your own map 6. Map 3 is only a half pound higher I believe then 2. If you look on page 197 of the top topic here you can find a post from Serstylz which is a great map 6 for a car on 93.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
baggy999's Avatar
Car: Q50 3.0T
Default 12-03-2019, 04:40 PM
Thanks @Lonmon, I'll check it out and give the Map 6 a try!
-Baggy
JB4
baggy999's Avatar
Car: Q50 3.0T
Default 12-12-2019, 09:58 AM
Just did a run with Map 6 loaded, please let me know what you think.
Thanks,
baggy
JB4
Default 12-12-2019, 10:32 PM
Thanks,
baggy
JB4
Looks generally OK to me. You're at the top of the fuel trim range adjustment but AFR isn't overly lean.
