Ripley's Avatar
Ripley Ripley is offline
Car: 335i N54
Default Z4 N20 hybrid turbo settings - 08-22-2018, 12:48 PM
Hi guys,
there are some values to change in the JB4 app under "User Adjustment Settings" for N20 hybrid turbo setup?
Like this: http://www.n54tech.com/forums/showthread.php?t=33200
Black Sapphire E92 335i AT: VTT GC 2.0 - VTT inlets/outlet - VRSF 7'' FMIC - VRSF 3'' d p s - JB4 G5 w/ FSB - AEM meth - Fuel-It stage 2 LPFP - BMS DCI - Phoenix Racing CP - TIAL BOV - NGK 5992 - KW V3 - Dinan camber plates - Brembo 8 pot - Pagid RST3 - Mishimoto 25 row oil cooler - Quaife LSD - M3 rear bar - xHP stage 3
Ripley's Avatar
Car: 335i N54
Default 09-04-2018, 01:22 AM
Bump
I can't go above 21 psi
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 09-04-2018, 04:55 PM
Do a log on map 2
Herc Herc is offline
Car: F20 125i
Default 09-07-2018, 11:44 PM
have you flash the car?
Ripley's Avatar
Car: 335i N54
Default 09-08-2018, 01:02 AM
Yes, the car has a flash. Waiting for a stock map by a tuner shop.
Car: F20 125i
Default 09-08-2018, 02:20 AM
Stock map ??? what you mean? forgive the ignorance isnt a stock map already on? Or are you talking stock for the hybrid turbo?
And when you say hybrid what is changed?
last q if the car is flashed why you need the JB4? Are you running WMI?
Ripley's Avatar
Car: 335i N54
Default 09-08-2018, 03:28 AM
The owner of this car is a friend of mine. He already had a custom flash, but not good. We contacted BMS and bought a JB4. He has a TTH 350 hybrid turbo.
Not WMI yet, but soon.
I adiviced him to go back to stock map (via flash) because imho that custom flash could interfere with JB4
Car: F20 125i
Default 09-08-2018, 10:28 AM
i see.. recent experience on a EWG 125i with the N20 motor demonstrated the other way round on that. Would be great if you guys sorted it out and share the knowledge. We got to dead end and we scrapped the jb4 because even when in map zero the timing values where not smoothed.
Ripley's Avatar
Car: 335i N54
Default 09-13-2018, 09:50 AM
Originally Posted by Ando @ BMS
Do a log on map 2
He did 3 logs (see attachment).
It does not go over 21 psi, with any map.
I tried also map 3 with meth disabled. With any additive, I can't go up beyond 21 psi.
After the last firmware update, we can't set Boost Safety beyond 21 psi with "N20 TMAP=0" (as the guide says for N20s with PWG).
On my N54 with hybrid turbos (N20 TMAP=1) I can set Boost Safety to high values.
Default 10-07-2018, 12:17 PM
Is your car EWG or PWG?
Ripley's Avatar
Car: 335i N54
Default 10-07-2018, 12:21 PM
PWG
