instantfob's Avatar
instantfob instantfob is offline
Car: Z4 35is
Default JB+ on B48x 330e PHEV - 03-06-2017, 09:13 AM
Is the 330e supported with the JB+ plug and play?
Need extra boost for hypermiling action.
Default 03-06-2017, 09:30 AM
We have not tested it yet, but expect it to work normally.
instantfob's Avatar
Car: Z4 35is
Default 03-06-2017, 09:41 AM
I guess my car can be a
instantfob's Avatar
Car: Z4 35is
Default 03-13-2017, 12:02 PM
What's a conservative setting to test on this new platform?
Now: 16 MB GLE 350 / 17 BMW 330e
Past: 85 Corolla GT-S / 98 MB ML320 / 06 S2000 / 08 EVO X MR / 11 G37S 6MT / 12 MBZ E350 Bluetec / 13 BMW ActiveHybrid5 / 14 MBZ E350 / 14 Smart Electric Drive / 15 BMW i3 BEV / 15 BMW Z4 35is
Default 03-13-2017, 12:35 PM
Half way is a good starting point. Around 2psi over stock.
macrorain macrorain is offline
Car: BMW 330e
Default 05-16-2018, 09:58 AM
How did the jb+ work out on your 330e?
Car: BMW 330e
Default 07-22-2018, 09:37 AM
So, I installed the JB+ on my 330e a while back and it worked just fine. Toke about 1 minute to install, and in general I'm happy with it. The boost seemed to peak a bit high, so I've actually dialed it back a notch or two from the original setting. I've got the BMS intake + custom exhaust, not sure if that can be the cause of the somewhat higher boost.
What I'm seeing as compared to the piggyback system I've used earlier, is that the effect curve flattening out earlier.
The blue curve below is JB+, while the red is an european piggyback.
This is made with a datalogger via obd2 + virtual dyno, so the actual numbers probably isn't perfectly accurate, but serves as a comparison. Both the runs below actually peaks at about 14psi, and starts backing off at around 4500-5000rpm, all the way down to around 9psi at 6000+ rpm. So the turbo pressure is relatively similar, but the piggyback system (four connectors similar to jb4) gives more power. I assume one would see a similar difference between jb+ and jb4.
The hp reported in the graph is calculated whp, but is quite close to the reported rating for the for the piggyback system, so is probably reasonably accurate.
