rif75's Avatar
rif75 rif75 is offline
Car: Bmw 335i N54 JB4 stage 3 + Bmw M5 F10
Default B58 with JB4 with MPPSK, what's the gain? - 01-24-2017, 12:02 PM
Hello Guys,
My boss is owner of a 340i with MPPSK and he want some more boost...Wondering if there is news in this thread? How much hp can we hope with the JB4 and the MPPSK.
Can we push a little bit harder like with an M5 ZCP?
BMW M4 JB4+DP and BMW M3 E92 Gpower Sk1
Default 01-24-2017, 12:30 PM
Install it and we'll need to evaluate and see. Worst case it makes the same power as non-PPK cars with a JB4. Best case we're able to make a little more.
Car: 335i, 2009
Default 01-24-2017, 02:50 PM
The best hope would be some timing improvements and maybe a little more headroom on fueling. But that's just a guess. Worst case it performs the same as a JB4 like the expert says ^^^^^
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
rif75's Avatar
Default 01-25-2017, 03:51 AM
Thanks guys, told already to my boss but since he's already making 360hp (engine hp), he don't want to take it to win 20-25hp. And he's not the type of guys who makes log to see what he can win.
I thought that the JB4 put more boost, for example +0.5bar than the dme. If the oem boost is 0.8 (don't know the real value), and for exemple 1.1 for the MPPSK, I thought the JB4 would give +0.5bar on the 2 cases.
Bullitt1841's Avatar
Default 01-25-2017, 11:57 AM
I am wondering this, as well. Does the JB4 just target an absolute boost in this case, or does it incrementally add to the DME boost?
If it works like the N54 JB4, I believe it just targets its own absolute boost target.
risktaker76's Avatar
risktaker76 risktaker76 is offline
Car: BMW 440XI MPPSK
Default 01-27-2017, 02:21 PM
Im interested in this too... Have a MPPSK car coming in April would also spring for a JB4, etc. if it had more then just the same gain without a MPPSK..
How about offer up a free return if it doesnt yield desired results for the first taker..
Default 01-27-2017, 07:14 PM
Maps 1-3 are additive based.
Default 01-27-2017, 08:06 PM
Good to know. Hopefully you can figure out the ethanol issue so we can take advantage of the added boost
acrhalo's Avatar
acrhalo acrhalo is offline
Car: 2017 BMW 440i MPPK
Default 01-30-2017, 06:36 PM
I've got a 440i with MPPSK kit on it. I've got the JB4, 4" DP, and BMS Intake on order with Mike, should all be installed in the next week or two. What sucks is the tracks don't open up till April here in Canada! Lol
Default 01-30-2017, 08:20 PM
Keep us posted
acrhalo's Avatar
Default 02-11-2017, 09:47 PM
Here we go... 440i with MPPK Kit ER ******** and BMS Intake. I took her home and added The JB4 https://youtu.be/6CWZktF8g_M
rif75's Avatar
Default 02-12-2017, 01:13 AM
Very interesting et sounds great, do you plan a dyno soon? So we can see the difference with or without the jb4 with the MPPK?
Default 02-13-2017, 02:30 PM
DYNO?
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 02-13-2017, 03:20 PM
Do the JB4 maps offset crank position sensor signal to pull timing? If not, it'd be cool to run MPPSK + Map 1 + E15 if the fuel trims allow. Even 15% ethanol gives a noticeable amount of timing headroom.
rif75's Avatar
Default 04-06-2017, 03:08 PM
Any news on that? Any dyno results with the mppk and jb4
Default 04-06-2017, 04:41 PM
No we lower timing using another method, when needed. The platform is not very E85 friendly. Maybe a small mixture would be workable but generally speaking the more E85 you add the less power you make.
Default 05-01-2017, 06:51 PM
Any recent feedback? How's it going?
Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default 05-02-2017, 05:40 AM
Acrhalo [440i owner in YT clip] may not have too much to share ???
My read of 3months+ silence is probably quite telling ie not good news for B58 MPPSK cw JB4
F20 M135i EB AT with options - what a hoot !
Default 05-02-2017, 05:53 AM
Maybe its so amazing he feels no sense to come back and tell us about all the greatness he has achieved with this mix?
Car: BMW F20 m135i
Default 05-02-2017, 06:25 AM
Let's hope ur right and I'm wrong :-/
Default 05-02-2017, 07:37 AM
I am able to run E20-E25 at a flat 17.0 PSI with the MPPSK. Terry said there is a slightly higher fuel ceiling with the MPPSK, but not much.
All I can say is with only 91 octane available in CA, I am definitely happy to be able to run a decent mix of ethanol. Car is quite a bit faster than stock and logs are quite safe.
Good enough for me until the flash tuning becomes available. Oh, and the MPPSK is so much fun to mess with
Default 05-02-2017, 08:15 AM
What map you running?
Have you changed the default values?
Your the only one who has posted any positive (or other wise) usage of a jb4 on mppsk
I'm on the fence between jb4 and jb+
Default 05-02-2017, 08:21 AM
With the JB4 Bullitt as also added in the fuel pressure control connector which lets us extend his fuel trims slightly. Since we have more room to work with on fueling with the PPK it's a good use of it.
Default 05-02-2017, 10:44 AM
Terry, Not looking to do anything overly aggressive, how does a JB4 with MAP 1 on MPPSK pair? Is this still experimental or a plug and play?
You mention fuel pressure connector, are you saying without MPPSK (on the b58 motor) it not used? With the MPPSK there is a slight improvement over fueling?
Im torn between JB+ and the JB4 - any advice based on the above?
Default 05-02-2017, 11:49 AM
PPK and map1 works great.
If you are torn get the JB+ from us since we give you 1 year to trade it up for a JB4.
