Seavita Seavita is offline
Car: BMW 335 CSI
Default 08-20-2013, 06:26 AM
Quick question, on the logs with the pedal at 100 and the rpm's climbing (1st log right away almost and second in the middle) why does the trottle drop out so hard and then come back during the pull? I have noticed this sometimes on my car and just curious as the car doesnt seem to slow why does it do it?
Sleeper edition Cabrio 3 series
Performance: JB4/G5 ISO MHD Flash, RB's and HiFlow oil returns, BMS DCI, PLM ***, cp-e FMIC & OC, aFe scoops & Throttle body spacer, Alpina TCU Flash, Stage 2 LPFP bucketless and Platinum PI by SteveAz, Mspec LSD, Cp-e charge with tial BOV, RB inlets and VTT outlets (let them fight my car doesn't care)
uluj333 uluj333 is offline
Car: bmw
Default 09-08-2013, 05:10 AM
BMS N20 Tuning Box, 4psi setting adjusts how?Setting out of box? Setting up the software is? (default 3psi?)
Thank you ...
amorak amorak is offline
Car: F30 320i
Default 10-26-2013, 09:39 PM
Any more updates on your 320i tuning?
Default 10-27-2013, 09:05 AM
No updates at this time on it.
thescout13 thescout13 is offline
Car: 08 335i coupe
Default 07-01-2014, 10:08 PM
Hey terry if all I have access to is 91 octane, can I still up it to +4 on the Stage 1, or should I only up it to +4 if I have 93 or some e85 mix to up the octane?
Presidio335xi Presidio335xi is offline
Car: 2008 Xi Coupe
Default 07-02-2014, 08:51 AM
Originally Posted by Jeff T
Nobody really knows, but I do know that our local BMW dealer is hiring 7 more salesman due to the expectation of sales of this vehicle. Its done well in the Euro, and Canadian market so far.
Also there are spy photo's and blogs about the X1/X3 20i as well as (don't laugh) the 420i. That's one car I would not de-badge. Not sure if the US would get the 420i due to the price point and lack of ponies but this N20B doesn't seem to be going anywhere soon. DP's would help this car out a lot. Terry has already pulled more then 30 percent more power out of our shop car with just tuning alone.
They are scrapping it in favor of the B48 (currently in the 2014 mini cooper s).
http://paultan.org/2014/02/25/bmws-n...e-255hp-400nm/
Car: F30 320i
Default 07-07-2014, 09:26 PM
Sorry for the late question, but I thought it'd be better answered here. What octane was run in these dynos? Hoping to hear the Stage2 run was 93 octane or something....
Car: 08 335i coupe
Default 07-19-2014, 09:20 PM
I have a 2014 320i with the jb4 and flex fuel wires. Drives amazing. Has anyone tried adding e85 mix to a 320i? what percentage? how did your logs look? Can you even do this safely?
Default 07-20-2014, 12:20 PM
The 320 likes E85. Start with a 30-40% mix.
fishmando fishmando is offline
Car: 07 335i
Default 08-19-2014, 12:43 PM
Any new updates on these?
tibookM3 tibookM3 is offline
Car: E92 M3, F32 435Ms
Default 05-10-2015, 04:51 PM
Ok, so just picked one of these up as a work car to put mileage on. It looks like there is one map specifically for the 320. What is the advantage to getting the JB4 if I'm not looking to do any additional tuning? Does the stage 1 include EWG control etc? I do want it to drive as smoothly as possible. But not looking to go full tilt like I have on my 435.
BMS JB4, Intake, FF and EWG harness, M Performance Exhaust, ER coated DP/CP, and a barrel of 104 octane
nongy85 nongy85 is offline
Car: 2012 F30 320i
Default 11-23-2015, 07:57 AM
Hi Terry,
Any updates on the N20 for the 320i yet?
You mentioned about trying to hit high 11's for the AFR's.. is it possible to be done just with the JB4 alone with the flexfuel wires? Or are you potentially looking at new injectors?
Would love to be able to hit those richer AFR's, then maybe that could unlock the potential to run on Map2 with 22-23psi boost..
F30 320i Alpine White 8AT
- GSR Technik Stage 2 ECU Flash
- JB4 Map 1 @ 23psi max boost
- ER C@tless DP
- Simota Carbon Fibre Air Intake
- Mach5 Dual Exit Valvetronic Performance Exhaust
- Mach5 Aluminium Charge *****
Aero1 Aero1 is offline
Car: 320i
Default 12-24-2015, 02:15 PM
260whp compares to approximately how much "manufacturer claimed HP" at the crank? I think I saw a dyno graph where the stock 328i made 230whp for 240hp claimed. Is there a formula or is 275hp a good guess based on the comparisons?
How come 320i gets whp=hp on this dyno test?
gscale gscale is offline
Car: 2013 320li
Default 03-11-2016, 07:05 AM
Will 320i have 11 afr in the future?
Default 03-11-2016, 09:04 AM
No the 320i runs in the high 13s.
CRJdriver CRJdriver is offline
Car: F30
Default 03-21-2016, 09:35 PM
So I went to EAS to dyno today and wow. Thanks so much for help with the FF wire. Your product rocks!
With just intake & 3" exhaust. Stock DP.
Car: 2013 320li
Default 03-31-2016, 08:22 AM
Looks +3psi is a bit better than +4psi? For +4 the peak torque 250 is on 2800rpm. It's not very useful for an AT car because of kick down. Map5 17psi looks similar, peak torque on low rpm. From 2000 to 5000 rpm map5 keeps around 250 torque while +3 or +4 psi has about 230-240 torque. For daily drive the difference between 17psi and +3psi is not obvious. Maybe I should lower the boost to +3psi using map6 for daily drive, and use map5 in more aggressive situation. Is it a good practice?
Car: 2013 320li
Default 09-28-2016, 09:42 PM
The knock problem finally it's fuel problem. In Shanghai the highest is RON 98 and it's hard to find. So I was using Ron 95+MMT and knock. Recently nearby gas station supplies RON98, now map5 is working with 20i.
Car: 2012 F30 320i
Default 09-29-2016, 07:01 AM
Gscale,
I've been running with RON97 and Map1 since i swapped out my stock DP with a ******* one. However, I set the boost safety to 21psi.... not had any problems since... i'm currently trying out Map2 with boost safety at 23psi....
- ER C@tless DP
Car: 2013 320li
Default 11-07-2016, 08:25 PM
Originally Posted by nongy85
Gscale,
Yes, 8at won't have any problem, I believe. 8at wont let rpm below 3000 when WOT at any gear(except gear 1). For 6mt, I need to carefully choose gear before WOT. When RON95, it's very difficult to avoid knock, such as gear 3 below 3000 rpm. When RON98, it's much easier to handle.
PuroMexicano PuroMexicano is offline
Car: 320i Sport Line 2017
Default 09-04-2017, 09:50 AM
Hi Terry
Have you made a new Dyno test for the 320i with the B48 engine?
alfanatix alfanatix is offline
Car: f30
Default 02-01-2018, 07:35 PM
With just intake & 3" exhaust. Stock **.
Hello terry and guys. Need your advise.
Currently my setup is jb4 without the ff and ewg wire(ordered waiting for it to arrive).
******* ******** with full exhaust system. On the current map3 (which is additive +6psi) only manage to get 230whp on dyno. Care to share how do u get that figure. And what are your user adjustments setting for jb4. Thanks terry and guys.
CntryClub007's Avatar
CntryClub007 CntryClub007 is offline
Car: F30 340i / E70 X5-35i
Default 320i N20 w/ Methanol Injection - 06-21-2018, 12:09 PM
Hi All - I hit the dyno in the 320i w/ Meth. Huge thank you to Ando @ Burger, he has been tremendous to work with on reviewing logs and overall support of the many questions I had.
Also, dynoing a car in Chicago is damn near impossible. Josh, ***hy, and Chris were all a pleasure to work with at P&L Motorsports (Subaru WRX shop). Very knowledgeable, and they were able to support my exact dyno plan in a quick hour over lunch. From setup to multiple runs on different JB4 maps, it was quick and efficient all from my iPad and the JB4 Connect Kit.
Car Details:
Model: 320i, RWD
Engine: N20
Intake: AFE Momentum
Turbo: OEM
Plumbing: ER Turbo to Intercooler & Chargepipe
Intercooler: VRSF Street
EDP: OEM
Exhaust: AWE w/ Mid-pipe
Tune: JB4
Meth Kit: Burger Tuning w/ CM7 Nozzle (Stealth Tank, Pump, FSB, etc...). WMI Boost Additive Setting of "55"
Methanol: Boost Juice
Fuel: 30% E85 / 70% 93 Octane
I did 3 runs of each JB4 map to make sure results were accurate and repeatable.
Map 0 - JB4 Off
Map 5 - JB4 320i Autotuning Map
Map 3 - JB4 Methanol Map
The boost levels achieved on each map were the following:
Map 0 - 8lbs
Map 5 - 16lbs
Map 3 - 22lbs
HP / TQ Numbers (Wheel) were the following:
Map 0 - 191 / 189
Map 5 - 245 / 254
Map 3 - 270 / 291
Overall I'm happy with the car. With the 320i being stripped down and RWD, when it goes into "Meth mode" you can certainly feel it. Watching the IAT decrease in temp vs. increase is great too. I hope to move to a 340i in a couple of years, but where I'm at in life, I'm certainly happy with the gains.
Happy to answer any questions for anyone considering the installation. I think I was able to complete the install quite cleanly between the trunk and engine bay.
https://ibb.co/gvi3VT
https://ibb.co/kXiRjo
https://ibb.co/b2Hmjo
https://ibb.co/d6VTx8
https://ibb.co/czbOVT
https://ibb.co/eAY3VT
https://ibb.co/erLHqT
