p0wyangz p0wyangz is offline
Car: 335xi
Default Can't go higher boost - 09-06-2018, 09:27 AM
No matter which map I am in I can't go much pass 11psi. Wedge bef tune.
Default 09-06-2018, 10:16 AM
Then you have an issue with your single turbo solenoid, wastegate, line routing, etc.
Step 1 is to put it on map1, turn ign on, engine off, press gas pedal down, check if solenoid is clicking.
