p0wyangz p0wyangz is offline
Car: 335xi
Default Misfire cylinder 4 - 08-04-2018, 04:11 PM
Hello guys. Just recently upgraded to a stage 3 lpfp along with pprt injection by bmp. Using a bms pi controller. For the first time I filled up with full tank of e85. Currently have the e85 St bef map flashed. On waste gatw pressure of 10.8 it doesn't misfire but anything higher it always misfires cylinder 4. Attached is a log
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 08-04-2018, 05:18 PM
I'd Say you need to check your plugs and i'd even try to swap coil number four with coul number three and see is the misfire follows the coil..
'14 435I RWD MHD "Shoup Custom Tune" BigBoost Stage 3 Turbo Spool FX-150 XHP Trans Tune VRSF Race Cooler VRSF CP BMS Intake Borla ATAK Exhaust Custom Down-pipe Stage 3 LPFP BMP4 EKP M Performance LSD Phoenix Racing PI Intake Manifold AIC2-P controller e85 3.5 TMAP NGK 5992 Plugs "0.020"
Default 08-05-2018, 11:01 PM
Misfires can be tough to diag.
How old are the plugs / which plugs are you running and at what gap?
Coil packs- always a possibility too.
TheDoctor's Avatar
TheDoctor TheDoctor is offline
Car: BMW 335i
Default 08-05-2018, 11:03 PM
Spark plug swap then coil swap then injector swap that is the approach that I would use.
335i M//, 07",IC, CP, BOV, LPFP stage 3, Meth kit, MHD ST,PI,PTE 6466, 32psi ~ 750whp
Car: 335xi
Default 08-06-2018, 03:50 PM
I'm using prescion racework coils. And spark plugs maybe 10-15k on them. Oem Bosch
Default 08-06-2018, 11:32 PM
Id double check the wiring / connector on cyl 4.
May be worth swapping out plugs as well-ngk 1 or 2 step colder
Car: 335xi
Default 08-08-2018, 09:12 PM
So it was indeed ****ty plugs. I swapped out for some ngk 2 step colder gapped at .020. runs amazing now. How does this e85 bef log look?
Default 08-09-2018, 11:51 PM
Overall this looks a good bit cleaner. Some corrections up top on a few cylinders- but nothing alarming imo.
What size turbo do you have?
