(#10451)
Default 04-27-2016, 11:15 AM
Originally Posted by mistawall
i plan on experimenting with the MHD only bef
In regards to leaving the white connector in or out. when using 4/4 setting.?
There is no MHD only BEF. There is an MHD only flash. To run that you'd go mode 4/4 and either leave white subconnector installed if you want the JB4 doing the boost control tuning (something the flash maps do poorly without custom tuning) or bypass the white connector for the flash to have full control.
On mode 4/4 with it bypassed map0 works as normal. With it installed map0 would result in no boost.
mistawall mistawall is offline
Default 04-27-2016, 02:43 PM
hey terry maybe you can point me to a post that explains the updates in 32_2 better
white connector out logging and guage hijacking only i get that.
with it connected I have to leave jb4 in map 0 or i will get no boost. is that what im understanding?
god i hate being a newb and sounding uninformed which i am because i am still newbish. anyway.
Thats what i meant. currently im on the JB4 PUMP gas BEF on 4/2. i wanted to experiment with the MHD Flash so i just wanted further elaboration into properly using the MHD BEF with the JB4 so i dont **** anything up. Ive re read it like 18 times now and i think i understand it.
is there a thread that goes into more detail about boost control and how it works
TFT inlets, charge pipe TIAL BOV
RISS **, Exhaust
Walbro 450
335is Clutch
BMS short shifter
VRSF 7"
Montego Blue 1M clone
@breakmywallet (instagram)
Kish2604's Avatar
Kish2604 Kish2604 is offline
Car: E92 335i
Default 04-27-2016, 04:17 PM
Terry.. Unsure if I am the only one but after loading the latest hex 32.3 I see the start up sweep doesn't go the whole way on the speedo.. Also the speedo alignment for the menus aren't lining up perfectly. I did try resetting the default for 335 metric and reset of the cluster to no effectm
|RB old gen|Jb4 G5|3" DP's|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
Default 04-27-2016, 04:20 PM
Email in a video and we can check it out for you. Might be something with the specific dash settings you run.
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 04-27-2016, 04:41 PM
Same here. The speedo guage sweep only goes to 160 km/hr. Tacho goes all the way though. Didn't bother saying anything coz i didn't think it was a big deal. I might just double check its on the right setting (metric)
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF DP|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
Default 04-27-2016, 04:46 PM
Oh I see the problem on the 335i metric dash startup sweep. Give this a whirl.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 04-28-2016, 08:59 AM
Done terry the new firmware fix the issue but still the speedo alignment for the menus aren't lining up perfectly.
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Default 04-28-2016, 09:04 AM
We ran in to a rounding issue on the 335 metric so it may not be perfect but should be close.
Moodster123 Moodster123 is offline
Car: 2009 135i
Default 04-28-2016, 11:43 AM
Terry, I just bought a 09 with FBO and I was wondering why I cannot access menus 10-15? My speedo stops at 9 and won't go any further. Any and all help would be greatly appreciated, thanks.
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Default 04-28-2016, 12:08 PM
Because you may not have a Jb4 G5 ISO.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Car: 2009 135i
Default 04-28-2016, 12:16 PM
How do I figure out what control box I have? And if it is the G5 ISO what would cause me not being able to access those menus? Thanks
Default 04-28-2016, 01:45 PM
Is it possible the problem is persisting to the 135i? updated to 32.3 last night and the speedo needle is off by a couple notches now.
N54 | Build Thread
ThaCuda's Avatar
Default 04-28-2016, 01:48 PM
Pull the JB4 box and check which board is in it. If you need instruction on how to access it, goto Burgertuning.com
Default 04-28-2016, 02:31 PM
No the startup sweep issue was specific to the metric 335i dash. You are a metric 135i dash?
Matt_Turner18 Matt_Turner18 is offline
Car: bmw 335i
Default 04-28-2016, 05:27 PM
How do you access the 0-60 timer? I can't seem to find it anywhere
Default 04-28-2016, 05:28 PM
No such feature exists in the JB4. JB4 Mobile might have a lower solution timer built in. I'd ask in the JB4 Mobile thread for addl details though.
Default 04-28-2016, 06:55 PM
No. Also, no sweep issues here.
On the other hand, I apologize as I mispoke earlier, its the Tach needle that's out of alignment, not the speedo.
N54 | Build Thread
wind wind is offline
Car: BMW e92 335i
Default 04-29-2016, 12:18 PM
I updated steering wheel controls with last Terry's changes. If anyone would like to use it:
Full
https://drive.google.com/open?id=1Tp...zn6PZCffkMWBNo
Short
https://drive.google.com/open?id=1Cl...DDLjB_OP8d4tRM
Car: 2009 135i
Default 04-30-2016, 10:28 AM
Terry, I pulled the JB4 today and written on the box in what looks like sharpie it says G5 on it.
Default 04-30-2016, 10:29 AM
If you post a photo of the board itself in the support area we can identify it for you. Such personal support requests to this thread though are deleted.
Blown95ImpalaSS Blown95ImpalaSS is offline
Car: 08 135i vert
Default 04-30-2016, 05:00 PM
135 here, just updated to 32.3 and dash is still out of alignment after 1/5 reset..?
Default 04-30-2016, 05:28 PM
See FAQ re setting menu 5.
Car: 08 135i vert
Default 04-30-2016, 05:38 PM
Got it. Thanks!
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 04-30-2016, 07:47 PM
The movement seems normal to me? The refresh rate for cyl1 is 10 times per second while cyl 2-6 are around 4 times per second. So maybe that is what you are seeing?
I notice that as well but did not know that cylinders refresh at different rate. I have 4/2008 n54 and selecting 4 or 5 do not activate cyl 2-6. However selecting 6 does. Any explanation why mine is different?
Default 04-30-2016, 08:26 PM
You match it up to your flash version. Which is the name of the back end flash file you loaded. If you haven't loaded a back end flash map yet, then do that.
