(#7976)
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 11-20-2013, 10:41 PM
ISO 27.9 Notes
1) Fixed a bug with map 0 throwing 30FF codes.
2) Various methanol safety changes discussed in detail here: http://www.n54tech.com/forums/showthread.php?p=284988
First, I to celebrate the release of 27.9. Then I . Then .
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 11-21-2013, 12:39 AM
Terry i was about to load up 27.8 tonight, is there any real difference between 27.8 and 27.9?
I never run on map 0!
537.75HP 540.63TQ
cartmanr6's Avatar
cartmanr6 cartmanr6 is offline
Car: 335i E90 LCI
Default 11-21-2013, 06:27 AM
Got the 30FF on the Autobahn on my way to my dealer.
Thought my turbo has bricked.
Thanks for the update Terry!
michaelalex17 michaelalex17 is offline
Car: 335xi coupe
Default 11-21-2013, 09:16 AM
is this a good thing or a bad thing?
Default 11-21-2013, 09:36 AM
Just another map 0 tweak between the two. If you never use map 0 then 27.8 is fine.
MathR601's Avatar
MathR601 MathR601 is offline
Default 11-21-2013, 09:46 AM
Searched for "30FF" on google to see what the code was related to... Didn't expect the results lol
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
GetSomeE92 GetSomeE92 is offline
Car: '09 E92
Default 11-21-2013, 05:31 PM
Lol.
335i Coupe: E85 BB flash, JB4 G5 ISO (map 7), DCI and 60% E85 blend: 11.7 @ 120 mph.
Former Best with JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
coolbho3k's Avatar
Car: BMW 335xi
Default 11-21-2013, 05:54 PM
Originally Posted by GetSomeE92
Lol.
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 11-22-2013, 12:00 PM
HI, im thinking of upgrading my map sensor to 3.5bar map. where can i get it as i dont see anyone selling on websites?
my car is bmw 335i e92 2007 automatic
jb4 g5iso
bms dci
fmic
catles ***
meth w/out fsb running on map 5.
anyone help please or i dont need the 3.5?
i want more boost!
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 11-22-2013, 05:55 PM
First you need different turbos and perhaps then a higher range sensor.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 11-22-2013, 06:25 PM
Originally Posted by robc1976
So 27.9 has all new meth changes correct? Can't wait to get my JB4 back lol!
Wott?? What happened to the Custom Cobb tune rob?
robc1976's Avatar
robc1976 robc1976 is offline
Default 11-22-2013, 06:36 PM
I want power, not smoothness
Default 11-22-2013, 07:08 PM
You can have both!
robc1976's Avatar
Default 11-22-2013, 07:49 PM
You can have both!
I just showed a GTO that exact thing! Man is it great to be back!
_ink's Avatar
Car: 335i DCT
Default 11-22-2013, 08:00 PM
I'm waiting for Rob to do testing on the new meth maps so then I can copy
robc1976's Avatar
Default 11-22-2013, 08:35 PM
I am running map 6 with a custom backend flash and car is a animal. I will be testing map 3 here in a few. I tried map 3 and it felt great...huge improvement!
mixhali mixhali is offline
Car: 2009 335
Default Which Firmware to is right for me? - 11-24-2013, 01:55 AM
Hi all, I have an older JB4 which I have inherited with my 335. I just nmanaged to get the usb cable installed and the firmware dates back to 2011. Im wondering if i can just go ahead and upload the latest g5 iso firmware or do i need to get a specific firmware for my jb4. My jb4 only has one of the 2 diodes mentioned in the clipping process.
Jnat Jnat is offline
Car: 09 335xi
Default 11-24-2013, 07:06 AM
Is there anything to gain with 27.9 if not on meth? I'm running 27.3, my car seemed to like that better then 4/5.
09 335XI /Cobb ATR TUNED 18.5 psi/DCI/2ND ***** '''''''/E20/Alpina/VRSF 7inch/VRSF Chargepipe with Tial BOV***
Default 11-24-2013, 07:13 AM
Anyone else have problems grabbing hex files here? Everything reads as attachment.php
Wonder if it is my pc.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 11-24-2013, 08:52 AM
Sounds like it is a G4 JB4. Don't try to upload ISO firmware. If you had a pic of the board I'm sure Terry or someone could ID it.
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 11-24-2013, 09:54 AM
27.9/BMS flash custom Map 6 50/50 93/100. To cold, 32 degrees in the sunny south, for WOT runs on summer tires but in DD car feels very good in DD mode, stick in sport mode button not pushed. No more bucking or hiccups at the 2900/3000 part throttle shift points.
As a matter of interest what is the point of diminishing return on stock turbo PSI?
EDIT:23 degrees this morning.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
Car: 335xi coupe
Default 11-24-2013, 02:38 PM
hello, i installed the 27.9 firmware update and i like it a lot. however, i noticed after installing it that when i unlock the car after the ECU is asleep it makes a weird noise for a second that sounds like its coming from under the car. I'm not talking about the car being primed. this is something else i have never heard.
Stucks Stucks is offline
Default 11-24-2013, 09:02 PM
Me too. It used t happen on one of the older firmware versions. When the car awakes, the wastegates move into positon or something like that. that is what the noise is. a click noise right?
Current: 2008 e92 335i coupe.
Car: 2009 335i AT
Cool 11-25-2013, 09:58 AM
No problem for me.
Car: 2009 335i AT
Cool 11-25-2013, 10:05 AM
That's too cold and it is not winter yet.
Since the problem with the OEM turbos is exhaust flow I suspect the limit varies with RPM.
Probably 18 psi low to midrange rpm and 15 psi up top.
JM $0.02
