(#7951)
crisart's Avatar
crisart crisart is offline
Car: 135i n55
Default 11-11-2013, 09:13 PM
Question, what does setting 4/2 & 4/3 suppose to do or when are we suppose to use them
Default 11-11-2013, 09:18 PM
If you need to ask you don't need to use it.
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 11-12-2013, 11:24 AM
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
v1nc86 v1nc86 is offline
Car: E90 335xi
Default 11-12-2013, 11:39 AM
Originally Posted by boostaholic
Isnt there a reason that you set up a "safety feature" to basically not put your lead foot to the floor when temps are under 160 degrees??? Can you guys really not hold off until oil temps reach 160 degrees, well for me I wait till its at least 180-200 degrees AND i have the BMS oil thermostat and I STILL will wait the extra 3 or 4 minutes to make sure the car is up to temperature... And for those of you that dont know, it says in the owners manual to start the car, let the rpm's sit where they normally sit which takes about 45 seconds, and then go drive the car MODERATELY so it can warm up the whole entire car, not just the motor. Theres a reason terry implemented a feature such as this because honestly going WOT with oil temps under 160 degrees ARE NOT GOOD FOR THE CAR OR TURBOS.... Especially the Turbos because they are oil and water cooled and the car needs to get up to temperature so it can lubricate its internal components of the Turbos...Everybody knows that oil looses its viscosity to lubricate properly when its cold.. Oil needs to be above 180 Degrees in my personal opinion but hey to each to there own....
well said
2008 Jet Black 335xi E90 6AT | Alpina B3 TCU Flash | BMS Backend 7/1 Pump Flash | JB4 G5 ISO 31.5 | BMS DCI | BMS CP | VRSF 5" FMIC | BMW Performance Exhaust | VMR V718 / Kumho | Best 1/4 mile: 12.37@110.4 MPH | Top speed: 0-270 km/h | YouTube
Grip&Go Grip&Go is offline
Car: 135
Default lolzzzzzzzzz - 11-12-2013, 02:22 PM
Bahraini 1er Bahraini 1er is offline
Car: 09 135i M Sport
Default 11-13-2013, 07:42 AM
Hey all 1st post here.
Just pulled the trigger on the Jb4+USB cable and can't wait till I receive it and install it.
I bought my car used and the previous owner had the Procede installed. Didn't like how it works, and right now I'm either facing couple of issues with it or with the car itself.
So I've decided to ditch it and install the JB4 and start fresh.
Great forum and many informative posts/threads. Cheers to that!!
Default 11-13-2013, 09:44 AM
Nice upgrade!
Default 11-13-2013, 03:46 PM
Thank you.
I have the n54 not the n55.
Sorry for the n00bi question but what's the ISO?
Default 11-13-2013, 03:56 PM
Originally Posted by Bahraini 1er
Thank you.
Thought I was in another section. It comes as ISO ready to go.
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 11-14-2013, 07:37 AM
I'm having fun with the gauge hijacking... I'm curious if there is any way to turn off the cold weather warning via JB4? That would be AWESOME
orau22 orau22 is offline
Car: E92 335i Coupe 6MT
Default 11-14-2013, 09:42 AM
So I have a few questions about the JB4. First off, I have it installed and I am in love with the car with this tune.
When I go to get the car inspected (NJ) should I put it in MAP 0 or will I be fine in MAP 1?
When installing the BMS ********* will I pass inspection or no with the JB4, I will be keeping the secondary *** on the stock exhaust?
I am just trying to figure out the future with these parts, in the event I have to take them out, its not a big deal, but was just curious.
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 11-14-2013, 09:51 AM
Map 0 and you will need the BMS DP Fix module to make sure you get 'readiness' which will be a pass for emissions. The DP fix tricks he OBD-II reader to think it has *** readiness.
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 11-14-2013, 10:04 AM
When you turn map to 0, that fuxn gets disabled. And the emission inspector's obdII computer will detect the ******* dp. Thus, you need that dp fix separately.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Default 11-14-2013, 10:07 AM
that makes perfect sense, I appreciate the response.
Default 11-14-2013, 10:27 AM
that was what I responded with
Default 11-14-2013, 04:08 PM
I now realize that, I just needed a little further clarification, but after re-reading what you wrote you gave me the info I needed, Thanks.
michaelalex17 michaelalex17 is offline
Car: 335xi coupe
Default 11-14-2013, 06:51 PM
Originally Posted by NewHotness
IIRC When you try to install the same version without doing an uninstall it will ask you if you want to repair or uninstall but not install.
Nope, just tried that. I think it should say the version number next to it on the n54tech page. just like the firmware updates for the jb4 have the firmware version numbers.
Car: 335xi coupe
Default 11-16-2013, 02:39 PM
6 5 Auto Radio - Disable
6 6 Auto Radio - Off (Non-iDrive)
6 7 Auto Radio - Off (2009+ iDrive)
Hello, i have a 2008 335xi, i have tried all of these options, but none of them seem to do anything. am i missing something?
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 11-16-2013, 04:06 PM
Do you know what you are trying to do?
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE DP's + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 11-19-2013, 04:12 PM
Terry, any chance you can get the 6-4 option (toggle DTC on/off) to work on the 1M???
Boy do I miss it..
Seavita Seavita is offline
Car: BMW 335 CSI
Default 11-19-2013, 04:22 PM
Boy do I miss it..
Really that 5 second push is really that painful......
I kid I kid.....
Sleeper edition Cabrio 3 series
Performance: JB4/G5 ISO MHD Flash, RB's and HiFlow oil returns, BMS DCI, PLM ***, cp-e FMIC & OC, aFe scoops & Throttle body spacer, Alpina TCU Flash, Stage 2 LPFP bucketless and Platinum PI by SteveAz, Mspec LSD, Cp-e charge with tial BOV, RB inlets and VTT outlets (let them fight my car doesn't care)
alexim's Avatar
Car: 1M
Default 11-19-2013, 04:24 PM
I kid I kid.....
lol not really.. it's a bit of a reach though and I sometimes forget and the tc cuts in way too hard.. it works on the 135, don't know why it doesn't on the 1m...
Car: 335xi coupe
Default 11-19-2013, 08:52 PM
nope! lol i figured one of them would disable the radio while i am using the jb4 controls so it doesnt change my radio volume and station but i could be wrong
Default 11-20-2013, 10:15 PM
ISO 27.9 Notes
1) Fixed a bug with map 0 throwing 30FF codes.
2) Various methanol safety changes discussed in detail here: http://www.n54tech.com/forums/showthread.php?p=284988
robc1976's Avatar
robc1976 robc1976 is offline
Default 11-20-2013, 10:29 PM
ISO 27.9 Notes
So 27.9 has all new meth changes correct? Can't wait to get my JB4 back lol!
