(#4651)
easy2speed easy2speed is offline
Car: 2012 GTR and 2011 335is 6mt
Default 07-20-2012, 07:41 PM
What about the g5 guys?
'16 M5 ZCP - JB4 and BCM
'16 M3 6mt - JB4 with intakes
'16 X5 50i Msport - Wife's
Sold:
'13 GTR - 800whp
'07 997TT - 700whp
robc1976's Avatar
robc1976 robc1976 is offline
Default 07-20-2012, 10:07 PM
Originally Posted by 335si
I am not expecting drastically different results since I am on stock snails, but would think my trap would pick up 1mph due to less taper at redline due to coming from an 18ohm board, no? I will be running G5 map 3, 80% meth w/cms 10, ***, FMIC and intake. Also have a fresh oil change However, the heat/humidity in central Florida is awful to say the least, so if I trap anywhere close to 115mph I will feel good...
You will see a difference, I am have stock snails...my PWM went from 118 to 59. My boost went from going to 17 tapering to 12 to going from 17-18 for a much longer range dipping to 15-16 right back to 18. It is a big difference, grabs boost a lot faster also!
robc1976's Avatar
Default 07-20-2012, 10:10 PM
I have a feeling it is on the way....trust me
335si's Avatar
335si 335si is offline
Default 07-20-2012, 10:12 PM
Originally Posted by az335iat
You will love the G5 compared to the G4 - 18 ohm.
Time for some drag radials!
Went to the track and the conditions were awful. Over 90 degrees. DA in the range of 2500 ft. I wasn't able to log as my computer was dead...Will get some logs tomorrow.
Ran best trap of 112.9mph
Full tank of 93oct gas with only 20% E85
CM10 Meth 75%
Map 3
AR ***
FMIC
DCI
I was only seeing peak boost of 15.5lbs. Weather blows. Night before was a little cooler out and I was seeing peaks of 16.5-17lbs. The weather really throws this car off.
-2007 335i - All stock
12.3@118+mph
-2007 Suzuki SV650 - Evotech FE, M4 Carbon Slip-on, Solo Seat
Default 07-20-2012, 10:14 PM
I have some G5 stuff for testing too.
mobilefitt's Avatar
mobilefitt mobilefitt is offline
M3 Eater (m3eater)
Car: 07 E90 Non Sport...Sleeper
Send a message via AIM to mobilefitt
Default 07-21-2012, 05:44 AM
hey, you G5 guys have a place to chat, You boost holding sobs.
Do I sound jealous???
Just happy to know that Terry doesn't plan to leave the G4 group by the way-side.
JB4 15ohm w/ FSB & CM10, ETS-FMIC, Evolution Race Works charge pipe, Forge DVs, AR *********, Injen dual cones, DIY catch can-vent to atmosphere, Koni FSD,TSW Donnington 18's, Bridgestone Potenza 760 Sports.
b00st b00st is offline
Car: 09 135i 6MT
Default 07-21-2012, 09:23 AM
Can't wait for new firmware next week! Anything that makes the E85 + meth combo even better than it already is definitely exciting.
imageautodetail's Avatar
imageautodetail imageautodetail is offline
Car: 335 e90 spt pack 6mt
Default 07-21-2012, 10:08 AM
CM10 Meth 75%
Map 3
AR ***
FMIC
DCI
did you adjust your user settings after g5 install, i didnt and say the same 15.5 at the track, went home and adjusted and now seeing 19.5
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 07-21-2012, 11:11 AM
Terry sent you some logs late last night when you get a chance
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
robc1976's Avatar
Default 07-21-2012, 03:46 PM
Won't you be over boosting....my over boost safety is at 18.
triggz triggz is offline
Car: E92 N54
Default 07-21-2012, 06:30 PM
It depends on meth %, gas, and supporting mods. My over boost safety is at 20.
JB4 G5 - FBO + Meth - 11.9@119
robc1976's Avatar
Default 07-21-2012, 07:20 PM
On stock snails or RB's? I use 50/50 E85 FBO minus meth and I believe I over boosted today lol!! Car shuddered had no power...turned off car, turned car back on and all was fine....no codes. I was thinking of turning my over boost to 18.5-19 instead of just 18.
335si's Avatar
Default 07-21-2012, 09:54 PM
No I did not adjust any of the settings. What settings should I have adjusted?
12.3@118+mph
rudypoochris rudypoochris is offline
Default 07-22-2012, 08:22 AM
I was told to set all map afrs to 60% of default. I too would like to have that info screen shotted like the G4 does.
335si's Avatar
Default 07-22-2012, 09:50 AM
For example, under the JB4 G4 board at 5000rpm it states an afr of 55 in the default settings in the "JB4 N54 info" post. Are you saying to adjust this setting to 33?
12.3@118+mph
335si's Avatar
Default 07-22-2012, 11:27 AM
Ha just noticed my meth flow scaling was set to the incorrect value. I am running the FSB so I set this to 60. Also, noticed my boost limit safety was set really low as well, so I set this to 19.
Now I am seeing much higher boost levels! 17.6 psi peak tapering to 15.2psi up top! I am happy again!
Edit: This was also logged in humid central Florida in 94-95 degrees Fahrenheit. Noticed my IATs were 104 pre meth and went down to 84 degrees Fahrenheit with meth spraying. It looks like the Helix FMIC is doing its job as 104 isn't bad when the ambient temps are 94F.
12.3@118+mph
robc1976's Avatar
Default 07-22-2012, 01:19 PM
Are you running stock turbos?
drstorm drstorm is offline
Default 07-22-2012, 02:22 PM
Im just wondering why the boost's 1m specific map taper lower?
Default 07-22-2012, 02:29 PM
Because the factory tune is set to higher boost than normal N54 engines.
One of my friends dynoed his stock 1M and it posted 325 WHP and 360 torque. Bone stock.
335si's Avatar
Default 07-22-2012, 02:57 PM
yep
12.3@118+mph
robc1976's Avatar
Default 07-22-2012, 03:15 PM
yep
By boost argent s in the 17+ range...may have to raise my safety limit. I taper down to just below 15.
Default 07-22-2012, 05:11 PM
Is that 19psi boost limit only for upgraded intercoolers or will the G5 just lower the target anyway as the IATs climb out of reasonable.
robc1976's Avatar
Default 07-22-2012, 05:54 PM
G5 board IMHO is for FBO with E85 at least.
Throttle's Avatar
Throttle Throttle is offline
Car: 08' 335xi
Default 07-22-2012, 06:14 PM
Is there a way to run map 0 with only the DP fix on? My SES light comes on almost immediately when I switch to map 0. This will be really obvious when I need to take it in for service.
2017 BMW M2 in Mineral Gray
DCT Transmission & Executive Package
Speedtech Stg 3 (8374) l BM3 Jordan Tuned l AA Intake l ER Chargepipe l ER FMIC l Stage 2 LPFP l EOS Pump Controller l XDI-35 HPFP l NGK 97506 l Ohlins R&T l SPL Suspension Parts l RE-71 Rís l BMW M Performance Kidney Grills, Mirror Covers, Spoiler, Rear Valence l Full PPF Wrap l 35% Tint l
Default 07-22-2012, 06:17 PM
********* are pretty obvious too... Just run a clear code command before handing over the keys.
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
