(#4176)
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 03-31-2012, 01:55 AM
With 95 octane map 6 should not be an issue. On 91 definitely map 2. On good 93 octane it could go either way. We're looking for more 1M and 335is logs with the new settings so feel free to send the CSV files in and we'll use those as part of the dataset for future software changes.
Sounds like a plan & an extra $10 of 100 octane.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 03-31-2012, 08:37 AM
Wow Terry, this 3/7 firmware is buttery smooth, well done!
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
Stranger2k1 Stranger2k1 is offline
Default 04-02-2012, 04:53 AM
is there any info on what AFR values do exactly and how to change them in case of issues or more need for speed?
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Default 04-02-2012, 09:40 PM
Yes, it's in the first post under 3/7 firmware changes.
I changed the MethFlowScaling to 60 and now the oil gauge is showing higher than 100% when the meth is On! Before the 3/7 firmware update it used to show a little less than 50%. Is that ok to show over the 100%?
Default 04-02-2012, 09:42 PM
Yep!
Car: 335i 2007
Default 04-03-2012, 04:59 AM
Thanks Terry!
I wanted to make sure
Ed_Z Ed_Z is offline
Car: 1M
Default 04-03-2012, 08:23 PM
Wait till I get my package from you Mr T, you will have Plenty logs coming your way!
Default 04-03-2012, 09:09 PM
That's hardly a threat. He is like a kid awaiting Santa on Christmas eve. Every mail I ever have with the guy he is asking for logs.
Terry, how much for ***. "Send me your logs!"
Terry, my engine caught fire and JB4 stopped working. "Send me logs."
I tell ya he is obsessed with them.
Default 04-03-2012, 09:13 PM
A log is definitely worth more than 1000 words.
prelude2perfect's Avatar
prelude2perfect prelude2perfect is offline
Car: '07 335i
Default 04-03-2012, 10:06 PM
lmao
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Car: 1M
Default 04-04-2012, 06:59 AM
You guys really make me laugh!
RBloodscalp's Avatar
RBloodscalp RBloodscalp is offline
Power slide freak
Car: 09 E82 MT6 JB4 ST3
Default 04-05-2012, 07:30 PM
Hi guys if I run map 6 with 103 octane VP race fuel is it ok, I got ******** with full exhaust M performance, dual AFE cold air intake stage 2, light crank pulley, blow off valve and intercooler active autowerks, mod clutch valve, BMS oil catch can and Lsd Wavetrac. firmware 2/7 ????
What do you guys think.........safe or not at all
P.S I run daily map 2 and 5
If you are not going JUICE BOX then you are going SLOW
[N54 with RB`S, E82 MT, DCI aFe,CHARGEPIPE,SINGLE BOV&FMIC ACTIVE AUTOWERKES, NST CRANK PULLEY, 3' BMS DP, M PERFORMANCE EXHAUST, BMS MCV, BMS OCC, BMS 2STEP, JB4 G5 ISO board BMS Flash at 20.5psi]
xbox_fan xbox_fan is offline
Car: BMW 335i E92
Default 04-05-2012, 11:32 PM
Guess it depends on your map6 (since it is user adjustable)
I have been reading alot of negative about running a light weight pulley on the n54 though, maybe read some about it and make sure you're not getting in trouble...
Power slide freak
Wink 04-06-2012, 03:55 AM
For map 6 I will use setup from this tread here on page one.
I ve been running this light crank pulley for at least 20 000km now and nothing happen yet and its the dealership who installed it, but thanks ill look into it
itsmeek itsmeek is offline
Car: 335i, GT-R
Default 04-06-2012, 09:56 AM
Terry, is it possible to add a feature for xi's where the front wheels can be disengaged using the software? I know it's being done now by pulling a fuse, but it causes a windshield wiper malfunction and is a hassle to do.
Default 04-06-2012, 10:06 AM
It is possible but we don't own an N54 Xi model. If someone wants to drop one off for a week or two I can look in to it.
Car: 335i, GT-R
Default 04-06-2012, 10:09 AM
I'd gladly drop my car off to you- but i'm in DC
Any takers that live near BMS?
Default 04-07-2012, 10:35 AM
guys, what does the value "wastegate adaption" mean. i know that the JB4 sets it automatically according to the given circumstances but... does it tell something about my wastegates? currently, i have "41" as a value there, have heard from others that they have various values from 80-120.
Default 04-07-2012, 10:45 AM
It will continuously adjust to the car and conditions. The actual number isn't overly relevant to anything but lower numbers mean the JB4 is adding less duty cycle to hit boost target, and larger numbers mean it is adding more duty cycle to hit boost target.
Default 04-07-2012, 10:47 AM
ok, so no need to worry or even think about that value. was just wondering cause 40 compared to 120 seems to be a big difference at first sight without knowing what is behind that value.
thanks!
Default 04-07-2012, 11:02 AM
There is just a lot of car to car variation out there. The adaptive wastegate control has been a god-send in terms of support. I can't imagine life without it.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 04-07-2012, 11:55 AM
Ah, so, so true.
strayman strayman is offline
Car: bmw 335i
Default 04-07-2012, 03:26 PM
Hello what thinks about my log i 4 gear?
Default 04-07-2012, 03:34 PM
I don't generally look at logs on forums. You can email me the CSV file if you want me to look at it, or post it in the support section if you want forum advice.
Throttle's Avatar
Throttle Throttle is offline
Car: 08' 335xi
Default 04-08-2012, 06:23 PM
Just updated to 3/25 tune from 9/16. For some reason the car seems more subtle now. Boost seems to come in smoother on Meth Map 3 (40 additive). Also, brake boost launches seem less violent with no wheel spin when traction control is disabled.
Are any of you xi users dialing in more boost above the defaults in 1st and 2nd? I think I can add a bit more and still get a good launch on my Conti DWS.
2017 BMW M2 in Mineral Gray
DCT Transmission & Executive Package
Speedtech Stg 3 (8374) l BM3 Jordan Tuned l AA Intake l ER Chargepipe l ER FMIC l Stage 2 LPFP l EOS Pump Controller l XDI-35 HPFP l NGK 97506 l Ohlins R&T l SPL Suspension Parts l RE-71 Rís l BMW M Performance Kidney Grills, Mirror Covers, Spoiler, Rear Valence l Full PPF Wrap l 35% Tint l
