F8X_m3 F8X_m3 is offline
Car: F80 M3
Default Octane Booster Before&After - 10-06-2015, 02:45 AM
So From what ive been hearing alot of people Bashing on Fuel Additives. I have Yet to See a Decent product come out with something That actually works, Well Only from word of mouth. So 2 weeks ago being on a long drive home from work i decided to try to Jump on the Map7 Wagon Since I havent Been able To run it Lately Just Running a E85 Blend and racegas being over 45 miles from me, But It was A fail somewhat As i couldnt meet boost target and would get some sputter during mid range Rpm. Wel i was at Pepboys earlier today and a bottle of octane booster caught my eye, As to it saying Its not just an additive its actual race gas , Which may somewhat be true to and extent as to how much race gas is in this thing, Its a 32oz bottle and says if u treat 3oz per gallon you will be somewhat around 98 Oct, Well Today After I gassed up I I decided to give it a shot and put 3/4 of the bottle in there and Ill let you be the judge of the results due to I am not to well with reading logs but After Log does look like that additive did work
PLF's Avatar
PLF PLF is offline
Default 10-06-2015, 07:48 AM
What Octane was in your tank ?
Car: F80 M3
Default 10-06-2015, 07:57 AM
Ima say around 93-94 Socals **** 91 😥 considering I had e26 ish blend I usually put around 3 gallons for 13 gallons
Default 10-06-2015, 10:15 AM
The only octane booster that really works are ones that contain MMT like NOS Race. Wal-Mart has them for $10 per can.
Down4it's Avatar
Down4it Down4it is offline
Default 10-06-2015, 04:17 PM
Not a fan of the Torco product? Or is it the price compared to the $10nos can?
13F10M5 13F10M5 is offline
Car: F10 M5
Default 10-06-2015, 04:22 PM
Torco for me... I haven't seen anything off the shelf that works.
Car: F80 M3
Default 10-06-2015, 07:32 PM
Yes this current one I use contains MMT and there's proof in logs that this stuff works . Just don't use it on a daily basis I can't see that being to good for injectors etc
Car: 2010 535
Default 02-16-2018, 01:38 PM
why isnt MMT good for the injectors?
Car: F80 M3
Default 10-06-2015, 07:34 PM
Yes as this one contains MMT and Yes my buddy recommended me the NOS one Walmart super enter has them for 8.99$ racing formula . I want to try Octanium ☺️ By VP
Chromey Chromey is offline
Car: 09 E92 335i
Default 02-24-2018, 10:24 PM
Can any one shed light on Royal Purples octane booster. I hear that it is the best..
E-Rivas E-Rivas is offline
Car: F80 ZCP
Default 03-19-2018, 08:13 PM
2017 M3 ZCP, JB4, BMS intake, and charge *****.
I’m using royal purple on this tank, 93 octane, and I can feel the difference, running map 2. I feel a stronger pull using Royal Purple than running 2 gallons of e85 on a full tank of 93 octane. I also ordered Torco and Race Gas concentrate, I’m going to run one bottle each on 93 and see how they compare with feel. I’d like run on a dyno to compare as a controlled expirement, but so far Royal Purple has a noticeable difference on map 2.
Mrpink Mrpink is offline
Car: M140i
Default 03-19-2018, 11:04 AM
Boostane is independently lab tested. It works great.
Gab24m6's Avatar
Gab24m6 Gab24m6 is offline
Car: F13 ///M6
Default 04-06-2018, 04:00 PM
Will JB4 adapt to NOS Race?
Car: F80 ZCP
Default 04-06-2018, 04:08 PM
If you are able to mix correctly to raise your octane up to 100, you can run map 7 for F8x, not sure abouet F13. I added 48 ounces of Race Gas Concentrate, to bring up to 101 ocatne and was able to run map 7 without any issues. You can also add some e85 to bring up the octane. I have not tried NOS Race, but it should handle it if mixed correctly.
Gab24m6's Avatar
Car: F13 ///M6
Default 04-06-2018, 04:20 PM
Thanks for the response! I like the race gas idea better. When I click Map 7 after adding race gas I don’t need to do any other adjustments to JB4?
Car: F80 ZCP
Default 04-06-2018, 04:36 PM
No adjustments, needed with tuning, but make sure all of your connections are connected, fuel rail, EWG. Just read the mixture concentration, ounces of the race gas concentrate to gallons of gas to achieve the 100 octane minimum level. Then map 7 should be good to go. Again, I have an F80, I would assume similar for F13.
http://race-gas.com/
fast4d fast4d is offline
Default 09-07-2018, 01:58 PM
I remember using either torco or NOS booster about 15 years ago. I rember the content was orange in color
it left my spark plugs with a orange deposit
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 09-07-2018, 02:43 PM
Probably both they do..
The Demon and Hellcat guys only run Boostane when they're racing and go through the tank same day and throw a bottle of Techron Fuel Injector cleaner when tank is empty.
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
Car: 2010 535
Default 12-11-2018, 02:56 PM
So octane boosters with MMT leaves deposits behind, which is why they are bad for the injectors so the cure is to run injector clearner through the system after running a MMT based octane booster right??
Frikiton's Avatar
Default 12-12-2018, 01:59 PM
Yep it seems so, but most octane booster are ****.
Boostane and VP Octanium (has a new one now) seem to be the ones that work
