Car: q50
07-30-2019, 04:02 AM
Originally Posted by Serstylz2
Here's my logs from Saturday, can someone take a look? I was running an e23 blend.
Fuel trims are maxxed, likely because of the added E. Your fuel wires are either not turned on or the E content is screwing with them.
Car: 2019 Q50 Luxe
07-30-2019, 04:12 AM
Ensured they were enabled so I'll blame it on the E. Same thing happened when I dyno'd.
But that also makes me curious, if one of my fuel wires ever failed, the only way I would know is via hard logs like these, which would be rare as these were at the drag strip. I'll need to find a way to get at least a 1-3 log on 93 for a comparison to ensure the wires are ok
12.64 @114mph
0-60 4.46
Car: 2018 Q60 3.0
07-30-2019, 12:30 PM
mustang dyno? #s are extremely low if that was on a dynojet
Dynojet...after looking at your setup I'm thinking the same thing. Strange.
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Megan LDP
Car: 2019 Q50 Luxe
07-30-2019, 01:31 PM
Do you have any pictures of your dyno graph/curve?
12.64 @114mph
0-60 4.46
07-30-2019, 05:55 PM
Too many for me. Pick one and post it.
Car: q50
08-01-2019, 09:09 AM
Terry,
Is it possible to have the boost by gear only turned on on certain maps? I'm RWD and regardless of what gear I'm in when I activate boost by gear I get quite a bit of hesitation that goes away at the same speed and map when boost by gear is turned off. I would like to be able to run map 8 for roll racing/pulls, but switch to map 6 for dig races that limits boost in 1st for traction reasons. Since I can enable meth on the other maps, this would allow me to essentially have 2 meth maps, 1 for rolls and 1 for digs.
Car: 2019 Q50 Luxe
08-01-2019, 11:38 AM
Need some assistance. Just tried 4 different brake boost launches to test 0-60. Each time the car fell flat on its face after I left off the brake and no movement/boost until after 3k rpm. Best 0-60 was a 5.7 due to this. Bad fuel? Can someone check these short logs? Going to try again tonight in case heat was the issue but my IATs were around 137
12.64 @114mph
0-60 4.46
Car: q50
08-01-2019, 12:08 PM
Traction control on? What about the "secret" traction control button? My car will do that if I leave traction control on and get the start of wheel spin.
Car: 2019 Q50 Luxe
08-01-2019, 12:25 PM
On for the Map5 and Map6 pulls, off for Map3. Interesting though. Never happened before today. My tires didnt break traction at all, and every other launch I have TC on and break if I launch past 1500 rpm
12.64 @114mph
0-60 4.46
Car: 2019 Q50 Luxe
08-01-2019, 12:28 PM
I saw a boost spike on this one when I did a screen record. I suppose it's the best one to review
12.64 @114mph
0-60 4.46
Car: q50
08-01-2019, 12:55 PM
Be cool to see what happens if you turn off both buttons
Car: Q50
08-03-2019, 06:16 AM
Can you guys look at this log and give me some opinions, thanks.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
08-03-2019, 09:58 AM
Overall it looks OK.. The short term shift spike is just from the lower RPM shift and sudden turbine speed change. I wonder if you'd be better off letting it shift itself.
Car: Q50
08-03-2019, 04:32 PM
A couple of areas of concern. IAT of 167 degrees at the beginning of run. What is up with your cooling system? You're going over 220 degrees water temp. Fan and thermostat functioning correctly?
Car: 2019 Q50 Luxe
08-03-2019, 05:57 PM
90+ degrees at the drag strip. This was run #5 or 6 of the night
12.64 @114mph
0-60 4.46
Car: Q50
08-03-2019, 06:54 PM
I see. Running hot air intakes in these conditions doesn't help either.
Car: 2019 Q50 Luxe
08-03-2019, 07:51 PM
True CAIs would be nice... PPE should have done more to stay in business maaaan
12.64 @114mph
0-60 4.46
Car: Q50
08-04-2019, 01:59 PM
I still think that there's something up with your cooling system. Even in 90 degree weather and during very spirited driving the highest temp observed on my car was 195 after which it started to drop. Im assuming we have a 190 degree thermostat so something is amiss if you're logging over 220.
08-04-2019, 02:13 PM
I checked my recent logs - top water temp reading is 204 in mid/high 90’s & 50%+ humidity in NTX.
2017 Q50 Premium RWD - BMS JB4 w/ Fuel Wires
- BMS WMI w/ PM8s
- Pure Stage 2 Turbos
- Z1 PU Motor Mounts
- AMS HX w/ Aux Tank & IC Pump
- AMS HPFP (RA338) & LPFP
- AMS Flex Fuel Kit v2
- AMS LDP
- AMS CAI
- Fast Intentions Res. Touring 2.5 CBE
- Mishimoto Oil Catch Can
- EcuTek Flash (Seb @ Specialty Z)
Car: q50
08-05-2019, 05:15 AM
Coolant temps over 200 are not uncommon....IAT's in the 150+, I've never seen. We have true cold air intakes and that PID is the turbo inlet temp, not the intake manifold temp so it should be something remotely close to ambient. You shouldn't be letting the car idle forever in the staging lanes at the drag strip if that's how you got those temps...
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: q50
08-05-2019, 08:44 AM
Terry,
I think I found a bug. JB4 with fuel wires and WMI map 8. I have boost by gear set to cut 10 psi in 1st and 5 in 2nd. Check out the AFR when I hit 3rd gear and the boost by gear shuts off. Also check out the WMI AFTER the throttle is no longer 100%. Even after the pull it was hanging at ~82 on the gauge. I had to go WOT again and then let out to get it to go back to 0.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: 17' Q50 Premium RWD
JB4 MAP6 post fuel wire install -
08-05-2019, 09:45 AM
Mind taking a look at these for me Terry/Burger crew? Installed my fuel wires over the weekend and just looking for some feedback. Wires are holding mid 12 AFRs like a CHAMP! However, the second log raised some timing questions. Thanks in advance for any feedback offered, this unit rocks for those not ready to flash tune. Keep up the great work!
2017 Q50 3.0t Premium RWD
JB4
Fuel wires
HKS BOV
AMS LDP
AMS HX
AMS Intakes
Straight 93 oct
Reason: Add fuel grade
08-05-2019, 11:42 AM
What fuel are you using ?
- BMS WMI w/ PM8s
- AMS LDP
- AMS CAI
08-05-2019, 12:32 PM
Straight 93 no emix
08-05-2019, 03:21 PM
To run Map7 (@ 7.1+ boost over stock SS map) I had to run an E20ish fuel blend or I saw timing pulls.
- BMS WMI w/ PM8s
- AMS LDP
- AMS CAI
