Car: Red Sport 400
06-28-2019, 06:35 AM
Traction issues in 2nd? Looks ok.
No traction issues, still trying to figure out why it does this. With Traction Off/Manual Mode/Sports+/1st gear, if i dont shift before 6000 rpms in 1st gear, it bogs down in 2nd gear. I've read it does this to save the transmission?
With Traction ON, it short shifts maybe in the 5500-5800 range but doesn't bog in 2nd
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
12.19 @ 115.87 on 93 (Map 6)
Car: 2019 Infiniti Q50 sport AWD
06-28-2019, 07:07 AM
Drop your E content lol. Basically the computer can't hit the richer commanded AFR because the fuel system/trims can't keep up. Many of us max out the fuel trims, but we can still hit the target AFR. 1 other member in the meth thread had the same issue, but between his E content and meth, he has more safety cushion of a leaner AFR.
Damn I only put 4.6 gallons and 12 gallons of 93 octane.. maybe 2 gallons next time. Only did it because going to the track today.
Car: q50
06-28-2019, 07:13 AM
I have a similar issue if over revving in 1st, but its a throttle cut it doesn't stop mid gear.
06-28-2019, 09:44 PM
Could be over-revving in 1st and hit going in to the limiter in 2nd.
Car: 2018 Q60 3.0
06-29-2019, 08:05 AM
1500 3.5
2000 4.0
2500 4.5
3000 5.0
3500 5.5
4000 6.0
4500 6.5
5000 7.0
5500 7.0
6000 7.0
6500 6.5
7000 6.0
Runs like a bat outta hell.
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Megan LDP
Car: 2019 Q50 Luxe
06-29-2019, 09:01 AM
I can't risk that much extra boost that high in the RPM range
12.64 @114mph
0-60 4.46
06-29-2019, 11:02 AM
Originally Posted by RandyNester
1500 3.5
Would you happen to have a log of a 3-4 gear pull with this Map6?
2017 Q50 Premium RWD - BMS JB4 w/ Fuel Wires
- BMS WMI w/ PM8’s
- Pure Stage 2 Turbos
- Z1 PU Motor Mounts
- AMS HX w/ Aux Tank & IC Pump
- AMS HPFP (RA338) & LPFP
- AMS Flex Fuel Kit v2
- AMS LDP
- AMS CAI
- Fast Intentions Res. Touring 2.5” CBE
- Mishimoto Oil Catch Can
- EcuTek Flash (Seb @ Specialty Z)
Car: 2018 Infiniti Q50
Map 5 data -
06-30-2019, 05:50 AM
A quick pull on E30 and map 5. Terry? Would you mind taking a look before I move on to playing with Map 6?
06-30-2019, 09:01 AM
Seems OK but it's over-revving a bit. Are you letting it shift itself?
Track Day -
06-30-2019, 10:55 AM
Hello everyone so I went to the track for the first time on Friday and with the help from Serstylz2 on Map6 psi settings, after every run I made adjustments. My time got better and better.
I have a 2019 Infiniti Q50 Silversport Awd
Mods: JB4 with fuel wires
HKS lower down p!pes
Burger tuning elite heat exchanger
I ran an E30 blend.
Temperature was 93 degrees
Here were my times
First run- 13.362 @ 109.85 MPH left it in Automatic
I won against Stage 2 Subaru Wrx
The rest of the runs I shifted myself at 6,700 RPM
Second run- 13.032 @ 111.24 MPH- I won against Camaro ZL1, he spun.
Third run- 12.842 @ 113.02- beat my co-workers Audi supercharged A7 with upgraded supercharger pulley, Crank Pulley, upgraded intercooler, lower down p!pes, flash tune and running E85.
Last run- 12.748 @ 113.81- against Same coworker's A7 he beat me this time, his time was 12.561 @ 109.68 MPH
JB4 with fuel wires, EWG wires,
HKS lower down P!pes
Burger tuning heat exchanger
Car: 2019 Q50 Luxe
06-30-2019, 11:15 AM
Nice bro, any logs? Especially that last run
12.64 @114mph
0-60 4.46
06-30-2019, 11:31 AM
Here are logs of the runs at track day let me know what you all think, any dangers? Etc
06-30-2019, 01:05 PM
It's aggressive but seems to be working OK. Pull smoothly?
+9 - that’s really aggressive - WMI kit in your future ?!?
BMS WMI
- BMS WMI w/ PM8’s
- AMS LDP
- AMS CAI
Reason: Typo
06-30-2019, 01:39 PM
Surprisingly it pulled smoothly, not sure how far I could go up. I tried 7, then 8psi then 9psi. After that was a bit nervous so I stopped there. I guess I need more supporting mods like intakes and *** back exhaust for more power help it breath and get rid of the dumbflop tires. The A7 edged me out the second time, I feel like down low from a dig car fell flat on it's face even though I was brake boosting. Then power came in and was good, perhaps like @jrobohm said WMI kit could be another part i should get.
06-30-2019, 04:26 PM
At your level I think the bolt on mods will definitely help a bit! Check out our intake and inlet package. But 1/4 mile is all about the launch. What was your 60'?
06-30-2019, 05:42 PM
My 60 foot sucked it was 2.007
Car: q50
06-30-2019, 07:07 PM
1500 3.5
2000 4.0
2500 4.5
3000 5.0
3500 5.5
4000 6.0
4500 6.5
5000 7.0
5500 7.0
6000 7.0
6500 6.5
7000 6.0
Can't believe nobody commented on this. Are you seeing 20 psi in the logs? That's super aggressive for an RS.
Car: q50
That high gear looks like it's pulling timing don't you think?
Car: 2016 Q50 Red Sport
07-01-2019, 06:34 AM
Yeah I was wondering about that. That's super high foot an RS. I would not go any higher than +5 on an RS.
Your adding a TON of heat to your turbos which is going to eventually kill them.
2016 Q50 Red Sport
Ecutek tuned
Infiniti Sport Mufflers
Car: 2019 Q50 Luxe
07-01-2019, 06:38 AM
I made a comment about his scary boost at high RPM thinking he was in a SS...
12.64 @114mph
0-60 4.46
Not a Racer
07-01-2019, 07:10 AM
Quick question, once you done loading your file into your JB4 application on your laptop while being connected to the car, do you click Disconnect, or do you click quit >?
Also which one of these is the recent updated config For the Q50 Silver Sport
Car: 2019 Q50 Luxe
07-01-2019, 07:20 AM
JB4_VR30_7.hex is the most recent file.. but to confirm, do you have a JB1 or JB4? This are JB4 files
12.64 @114mph
0-60 4.46
Car: 2018 Q60 3.0
07-01-2019, 07:39 AM
I think this was the 4th gear pull.
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Car: 2019 Q50 Luxe
07-01-2019, 07:46 AM
got any time to teach me how to read logs? A high level 101 is all I need
12.64 @114mph
0-60 4.46
