F30N20MY F30N20MY is offline
Car: bmw f30 328i
Default JB4 EWG and PWG version - 04-22-2019, 12:52 AM
I have a full set of JB4 for N20 EWG with all the FF and add-on connector which i no longer use, My friend has a PWG N20 and wants to install it, was wondering if its possible. Of coz the additional wire that goes to the EWG controller cannot be re-used.
Cheers, j
Default 04-24-2019, 04:58 PM
Yes it's compatible although best to use the right system for the vehicle.
Car: bmw f30 328i
Default 04-25-2019, 09:19 AM
Thanks Terry, good to hear that I can reuse it on pwg. Can I leave the EWG connector unplug? Will it run given its not connected?
Default 04-28-2019, 10:52 AM
Yes just plug it in to itself to keep elements out and tuck it out of the way. It's only active if attached to an EWG wastegate.
Car: bmw f30 328i
Default 04-30-2019, 06:11 AM
Yes, sounds good. I assume I can do the same with the FF connector since he won't be running map6 as its a 520i so only map5
Car: bmw f30 328i
Default 05-03-2019, 07:26 AM
Hi Terry,
I have 2 additional questions, I noticed that there is a pwg connector the blue patch which my units does not have. Is this a MUST to connect to control the Pwg or it can do without.
Lastly, the current firmware is Ewg, so I assume once I start the car I can connect to JB4 blue tooth and flash it to PWG. Or I need to flash it before I start the car. Looking forward to hearing from you urgently.
Car: bmw f30 328i
Default 05-07-2019, 01:09 PM
Anyone can help with my enquiry. Thanks in advance
