Bmw-Munich-135i Bmw-Munich-135i is offline
Car: BMW 135i
Default How can i flash the PPK on my n55 - 02-22-2019, 04:10 AM
Hello
How can i flash the PPK on my 135i N55 2010 ?
keyap keyap is offline
Car: N55 135i
Default 02-22-2019, 05:57 AM
Either via a dealer/indy/tuner or yourself using WinKFP. WinKFP option sometimes results in a code/shadow code. You would then need NCSExpert to clear.
Why do you want the PPK? Either the JB4, MHD or a combination will deliver much better results!
[B]
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 02-22-2019, 02:28 PM
MPPK plus JB4 worked like a charm on my GT. 400/435 on basic boltons is strong with awd and no meth.
Mike Levy
2021 M550i - On hold due to lack of allocation
2017 X3 xDrive35i
2018 Equinox LT 2.0T
Car: N55 135i
Default 02-23-2019, 12:18 AM
For me, PPK on its own was fine but PPK + JB4 resulted in no additional performance and it proved harder to dial the car in with things such as timing issues which became worse as boost was increased.
[B]
