dysh.78 dysh.78 is offline
Car: BMW 440i xdrive
Default Map selection - 12-01-2018, 03:42 AM
Hi everyone!
I've got bmw 440 xdrive. I installed jb4 and down-pipe, so which map should I use? I ran 100 octane (Russian system), I guess it is 93+ in America
Romy_F30 Romy_F30 is offline
Romy_F30
Car: 2018 BMW 340i xDrive
Default 12-01-2018, 01:49 PM
Map 1 and 2 is good for now with just a down-pipe.
madking187 madking187 is offline
Car: BMW 340i 2017
Default 12-01-2018, 02:50 PM
Make sure to get EWG cable if you are having ***-less D0wnp!pe.
I will say try map 5, you have good octane and Russia have cold climate so I assume you should get good IAT degrees in WOT.
take logs and BMS can tell you best. Have fun
2017 340i M bodykit
mods:
Sport Springs
K&N drop-in filter
VRSF D0wnP!pe
JB4
Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default 12-30-2018, 09:41 PM
Map 2 is great. But map6 at 4 psi flat maybe better.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 12-31-2018, 01:15 AM
Only 4 psi? From 1500-7000?
I would run map5 if your octane is there
Turboh's Avatar
Car: 2017 BMW 340iX
Default 12-31-2018, 06:40 AM
After several hundred WOTs with all the maps 1 thru 6, at all IAT ranges, map2 and map6 at 4 psi flat have the optimal acceleration with the most timing advance, while using 93 octane.
Still fine tuning though.
