(#51)
Default 01-07-2019, 12:36 PM
Originally Posted by Zeezul
I installed mine about a week ago. Fitment was good. I noticed a difference. I have an 07 so I had to drill the holes from the frame. Wasn't too bad.
Keith
We just posted a new guide that explains the 3 options. No holes, offset holes, perfectly lined up holes.
http://www.burgertuning.com/instruct...ce_install.pdf
zomski101 zomski101 is offline
Car: 2009 335i
Default 01-10-2019, 11:18 AM
Originally Posted by CJ 135i
Does this piece add any extra noise or vibes to car? Similar noises and vibes like solid trans mounts make?
I put 1000 miles on the car and haven't noticed any extra noise, it's as if it was never there.
MMP stage 3 turbos with inlets and outlets, FBO, e50 mix tuned by Ken
CJ 135i CJ 135i is offline
Car: 2010 BMW 135i M Sport
Default 01-10-2019, 11:24 AM
Awesome. Thanks for letting me know!
Magnusk77's Avatar
Magnusk77 Magnusk77 is offline
Car: BMW 135i
Default 02-25-2019, 08:18 PM
How would the NVH be with solid subframe and poly diff mounts be? I wonder if I would even really need it...
2009 BMW 135i - Monaco Blue
Default 02-26-2019, 09:54 AM
No more NVH, and yes you would definitely want this even with those solid mounts. Makes a huge difference IMO, more reinforcement
eric84405 eric84405 is offline
Car: 2009 535xi
Default 03-08-2019, 02:20 PM
I hope this question isn't too dumb. Will this brace fit a 2010 535xi? It's not listed but I am hopeful it might fit...
vanosman vanosman is offline
Car: E93/F10
Default 03-10-2019, 08:12 PM
Is the new improved BMS catch can for sale now?
codesx codesx is offline
Default 03-11-2019, 09:19 AM
LOL, only for those that bought the NEW BMS Solid Rear Differential Brace.
Likely ideal to ask in a new Thread, or one that subject was discussed in
2008 335i Convertible, E93, N54, A/T (190,000+ km)
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
Default 03-11-2019, 01:37 PM
They're in the works, soon!!
landshark92 landshark92 is offline
Car: 2013 335is
Default 03-14-2019, 04:56 PM
Any videos or testimony on how much this brace reduces wheel hop? Smoothly rolling into it and breaking loose is something I enjoy doing but this wheel hop is killing me and I'm afraid it will kill my car someday.
RTA RTA is offline
Car: 335
Default 03-16-2019, 06:41 PM
Is this different then increasing the rear spring weight?
I have JRZ R1 with linear springs, m-sport stabi and a drexler diff.
Would this add benefit? Since I changed my springs, most wheel hop is gone (At least I think so ;-))
Magnusk77's Avatar
Car: BMW 135i
Default 03-16-2019, 07:05 PM
Completely different purpose and function than springs. The diff brace will reduce the actual movement and rocking of the differential itself (because under power it can physically flex the soft bushings that hold it to the subframe), which can be compounded with incorrect suspension and lead to wheel hop issues.
Car: 2008 E93
Default 03-16-2019, 08:21 PM
Exactly. While springs and shocks can help the car squat and plant itself on launch it does ZERO for actually stabilizing the diff.
RTA RTA is offline
Car: 335
Default 03-17-2019, 01:42 PM
Then I will probably order one in the name of science ;-)
Thank you for your explanation.
RTA RTA is offline
Car: 335
Default 03-17-2019, 01:43 PM
Just wondering, why would car vendors not include this in their standard?
lightning lightning is offline
Car: BMW 1M Coupe
Default 03-18-2019, 12:47 AM
Hi guys @ Burger can you please design one for the 1M/E92 M3 M Differential?
Car: 2008 E93
Default 03-18-2019, 12:54 AM
Probably because its not really an issue at stock power level. Cars from the 60s with leaf springs , generally did not come with traction bars either.
Its like asking why dont all cars come LSD equipped ? Or with racing axles, or beefier driveshafts, etc.
Car: 2009 535xi
Default 03-18-2019, 12:32 PM
Since vanosman hijacked the thread, I think my question was missed.
Will this brace fit a 2010 535xi? It's not listed but I am hopeful it might fit... Thanks!
Default 03-19-2019, 12:25 PM
Don't think it would, got any pictures?
