Default NEW BMS Solid Rear Differential Brace - 11-21-2018, 11:14 PM
Been testing these on a few of our cars from 300-800+whp. Keeps my rear end planted and more solid when doing pulls. No more wheel hop either, this little modification made a huge difference!!
Features and Benefits:
-Tightens chassis
-Reduces wheel hop
-Reduces differential bearing Load
-Stainless steel hardware included
-Precision made one piece design for a perfect fit
-Heavy-gauge steel construction for maximum strength and durability
-Easy install
-Made in USA
Click the link to purchase special intro price of $99:
Default 11-21-2018, 11:26 PM
w00t!
lightning lightning is offline
Car: BMW 1M Coupe
Default 11-22-2018, 04:25 AM
Does this fit M differential on the E82 1M coupe?
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 11-22-2018, 07:26 AM
Nice!! That’s great for you rear wheel drive guys! I remember having the same trouble with my Mustang and traction bars made a huge difference but that was in 1991 lol!!
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 11-24-2018, 03:15 PM
What is different about this vs other braces that have been on the market?
Default 11-24-2018, 04:21 PM
Probably similar. Ours is a one piece design with no welding for longer life. Plus this one comes from BMS so you're supporting us and the forum...
Default 11-25-2018, 10:10 AM
Yes I believe so, I think those are small diff type.
moss's Avatar
moss moss is offline
Car: 2012 335iS
Default 11-25-2018, 10:24 PM
Will this fit a E93 with the undercarriage bracing?
Car: BMW 1M Coupe
Default 11-26-2018, 04:17 AM
Thanks Terry, but it seems like thereís no place to bolt the brace. Can you advise? Iíve attached a photo
Default 11-26-2018, 09:09 AM
Attachment 81546
Awesome to see the mass differences in the rear suspension of the 1M vs a regular 1 series. Thank you for the picture, no it will not fit
Default 11-26-2018, 09:10 AM
It should fit no issues, I don't recall any undercarriage under the rear end. Got any pictures for me to verify for you?
weebles weebles is offline
Default 11-27-2018, 07:20 PM
Awesome! Will definitely be adding one of these to my next BMS order
Default 11-27-2018, 10:56 PM
We literally sent out about 20 today. Once you guys get them install and post pictures!
eric84405 eric84405 is offline
Car: 2009 535xi
Default 11-29-2018, 12:53 PM
I am going to assume no E60 535xi fitment? Would it even be beneficial? Thanks.
Logan's Avatar
Logan Logan is offline
Car: E90' 335i
Default 11-29-2018, 02:16 PM
Curious,did you guys come up with the dimensions?would their be a issue with the bottom bend that connects to rear diff?heard this from the other guy that makes these to before bms did and that the bottom where it tapers should be wider.bms brace is a little cheaper but worried about that.
Default 11-29-2018, 03:58 PM
This thing will not break though and fits perfect, it's bent and cut to the exact dimensions. This is much stronger than the welded pieces. I've gone through 2 of them on my 800whp car. This one has no weak points, it is 1/4" steel laser cut and bent on a 40 ton CNC press brake that barely bent it. Imagine if 40 tons could barely bend that what force you need to brake it.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 11-29-2018, 04:06 PM
Would this work on the F30's?
Default 11-29-2018, 04:08 PM
No, we are working on that though
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 11-29-2018, 04:14 PM
Thanks Terry, but it seems like there’s no place to bolt the brace. Can you advise? I’ve attached a photo
Attachment 81546
Oh dang that's a nice 1m!
Im pretty sure it's because the diff has cooling fins and is a different design there won't be a place to bolt the brace onto it. I wish there was an option for us guys with M diffs.
Mods: Stock for now
Logan's Avatar
Car: E90' 335i
Default 11-29-2018, 07:38 PM
thanks for clearing it up!will be ordering one!
THE BEAST's Avatar
THE BEAST THE BEAST is online now
Car: 2008 E93
Default 11-29-2018, 10:25 PM
What happens if a bushing fails while this is in place ? Would it risk cracking the subframe its bolted to or the diff casing itself ??? Bushings are used for a reason, this deletes it out of the equation.
THE BEAST's Avatar
Car: 2008 E93
Default 11-29-2018, 11:41 PM
A 40 ton press would bent it like butter. I can bend (and do so on a daily basis), 1/4" steel with a bench vise and vise grips with a small piece of tubing for leverage. Its a nice piece, the product will sell itself. On another note, any others that are welded, if done CORRECTLY will be just as strong. I reinforce suspensions ( make custom parts as well) and car frames on a daily basis and am also certified welder for oil refineries.
Default 11-30-2018, 10:30 AM
It depends on the area you are actually bending, maybe his press brake is weak. I doubt it though because his 55 ton press brake that isnt CNC took some force too.
Welding has weak points comparing to a solid piece, period. We've done the testing, along with a certified aerospace welder lol... still broke. This is the best way about it to be honest.
THE BEAST's Avatar
Car: 2008 E93
Default 11-30-2018, 06:18 PM
Yeah, its a good thing Navy ships, Bridges, Cranes used to build skyscrapers and lift TONS worth of steels beams , submarines, fighter jets to protect countries, tanks, etc are made out of 1 piece for strength !
Relax Payam, just messn with you. As I said , its a nice piece and Im sure will sell well.
Default 11-30-2018, 06:39 PM
I think Payam's point was he's broken two of them from another vendor (who he's purposely not naming to avoid a flame war), before we decided to just make our own one piece units. And the one piece units have been solid for us.
