Default E85 cold start issues? - 11-11-2018, 11:27 AM
Noticed lately our white 135 is difficult to start on straight E85 when temps get below 50F (not common in CA!) so I've been reworking the cranking fuel tables. Anyone else have a similar issue? If so email me could use some help testing the changes.
Default 11-11-2018, 11:42 AM
My 335i doesn't have that much issue like your 135i. I'll test it a bit more later when it gets real cold.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 11-11-2018, 09:44 PM
Yeah that happens alot here in canada (I used to run it by the barrell until we got a pump here where I live), I'd love to help but currently my m2 is not equipped to run E85, but I remember cobb made some changes to their ignition and crank tables to make it start easier on subarus maybe reading up on that will give you a place to start.
Anyways good luck, I hope you figure it out so I can run E85 in colder weather when it comes time to get PI.
Mods: Stock for now
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 11-12-2018, 07:20 AM
If you set the tables properly in the tune, this is a non-issue no matter the temperature. Fuel (Start) is cranking, and then Warm-up Enrichment is post start, open loop enrichment, used until the lambdas are up to temp and it switches to closed loop.
The Warm-up enrichment was not added to the regular xdf yet, but it's in the FF xdf, you can copy and paste the xml to the normal xdf. Just be sure to grab the pump gas one and not the E85 table, because that doesn't exist in a stock logic rom
suspenceful's Avatar
Car: 2008 BSM 135i
Default 11-12-2018, 07:30 AM
Yes - it's always been an issue for me in Wisconsin. Even on warmer days, it'll stumble for a second. Anything below 50*F and it's angry. I'm putting pump gas in this week and storing it for the winter though.
chadillac2000's Avatar
Car: 2008 535i
Default 11-12-2018, 08:51 AM
Been running between E60 and E70 for a few months and lately in this sub 50 degree weather it's stumbled for a few seconds. Usually clears up pretty quickly though. i think my 950RPM idle helps. I think I would have a lot more trouble at stock idle.
One morning recently in the 30s running E70, when I already had auto climate control set to 75 prior to starting and the AC button was activated, the car really stumbled on itself and died a few times before I could apply some throttle in neutral and get things back to normal.
chrisdfv chrisdfv is offline
Car: 2008 335i
Default 11-12-2018, 09:21 AM
I've had my tune set up the way explained above. Never have an issues on E85(no blend). Starts right up.
Default 11-12-2018, 09:34 AM
Stumbling is one thing, just not starting is another. Looking to correct any cold weather starting issues we have on the OTS BEF maps. But it only gets so cold in CA.
Default 11-12-2018, 09:38 AM
You just need to wake up earlier. When I leave the house it's 40*
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 11-12-2018, 02:43 PM
I’m having the same problem starting as it has been going through the whole crank cycle and still not starting. Also stumbles when it does start for a few seconds. I’m in NY so it’s been pretty cold here but I’m mhd only.
Ron Vogel Ron Vogel is offline
Car: E61 535Xi
Default 11-12-2018, 08:19 PM
I walk out of work to my car at 3:30am...so it better start! Had no problem last night on E40 thankfully
BevsM3's Avatar
Default 11-14-2018, 06:22 AM
It will start just may take a second. E40 was completely different for me when starting, had no issues but the e85 is tough.
dyezak dyezak is offline
Default 11-16-2018, 02:09 PM
Justin (v8bait) used my car for testing his cold start e85 crank settings last year. Flawless single crank startups even at 18F last winter on full e85.
jReNeo jReNeo is offline
Car: 08 335i E90
Default 11-20-2018, 08:30 AM
I'm currently on the OTS ST BEF and gave up on starting this morning - temps were upper 30's where I am. Still need testing?
Default 11-21-2018, 09:42 AM
Definitely! Email me the BEF you have loaded and let's try a few things.
BOosted 335i's Avatar
BOosted 335i BOosted 335i is offline
Meth Addict
Car: E90 TiAG 335i Sedan
Default 11-22-2018, 09:35 AM
Agreed!
it's 19 degrees here now on ThanksGiving morning and my car started with e85 no issues at all,no stumble thanks to Justin"v8bait's" tune with cold tables.
E90 335i Auto, Cold Weather, & Sports Prem. Package, Navigation
Mods
: JB4/MHD, ACF ST, Precision T/S 6062, AD-Eng Mounts, Precision RaceWorks Stg 3+LPFP, //HPF Exhaust Titanium Tips, Custom HighLow OCC, Precision RaceWorks Coils,RACE InterCooler, Custom Meth Kit, Justin(v8Bait)Tuning
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 11-24-2018, 08:18 AM
Ya know, you guys could always just ask what table values I'm using, and I could probably be enticed to share them...
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 11-24-2018, 09:52 AM
Mine does it when I put to much e-85 .It cranks always at the second start .Whether
is not an issue . I'm from Miami.If change to 93 no problem.
Default 11-24-2018, 11:47 AM
The hardest part has been finding a car that has starting issues to test table changes. But you've got some good values I'd be happy to throw them in our BEF and throw a Kudos your way.
nyt nyt is offline
Car: 335ix
Default 11-24-2018, 12:30 PM
What table values are you using? It'd be great to have this information available and much appreciated
2010 335ix - pure 600 turbos @ 30psi, dps, cp, 7.5in hd ic, inlets, outlets, jb4, pi, fuel-it stg3, at cooler
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 11-25-2018, 01:24 AM
Would you make one for n55 as well? Mine starts when cold just longer cranks and rough for a little while I'd love to run e85 all year if possible
2018 Individual Tanzanite Blue Competition M4
BevsM3's Avatar
Default 11-25-2018, 05:21 AM
That would be extremely nice of you, it would help a lot of people as more and more are moving to full e85.
v8bait's Avatar
Car: E92 335i 6MT
Default 11-25-2018, 08:04 AM
Sure. You need the table address for warmup enrichment factor, it's in the FF XDF's you can just copy the address and scaling from those to the normal XDF's.
Technically you could increase the enrichment factor a lot at warmer temps too but I've never found the lean conditions at startup a problem when it's warm, only when cold. And unlike some people say, with full E85, as it gets colder outside, you need more than the typical 40% increase compared to pump gas. Anyone that see's negative temps and uses E85 can tell you that.
Tested these down to -10*F without issue on 90% ethanol.
v8bait's Avatar
Car: E92 335i 6MT
Default 11-30-2018, 11:15 AM
I'll make this even easier for your customers:
Adding cold-start by using your normal XDF, and the FF XDF:
1) Open your backend with the XDF for your DME version and modify "fuel (start)" to generally match the large table posted above, doesn't have to be identical (or copy/paste from attached xls sheet), save the .bin
2) Now, use the FlexFuel XDF available here https://github.com/dmacpro91/BMW-XDFs instead of the normal XDF, and modify the "warm-up enrichment factor" to match values above for the small table (again you may copy/paste from the xls sheet attached), save the .bin
3) Flash your new backend and profit by not being late when it gets chilly anymore because your car will now start perfectly every time.
4) Buy me a beer with all the extra money you will be making.
*NOTE* Do not change other tables using the FlexFuel XDF unless you know what you're doing, only change the "Warm-up enrichment factor".
Alternate method, adding tables to your normal XDF:
If you want to add the table to the normal XDF, I also attached a .txt with I8 and IJ addresses, add these to your XDF file and then you don't need to use the FF XDF to change the single table. If you want me to do all the work for you I will but I'll charge you something for it. Enjoy ya'll
Car: 2008 535i
Default 11-30-2018, 11:29 AM
Thanks Justin! Looking forward to Terry throwing this coding in the BEFs so I can flash it up. These 20 degree mornings running full E85 have been rough.
