(#101)
wilcoxclay wilcoxclay is offline
Car: 2014 Ghibli
Default 01-29-2019, 05:59 AM
93 pump
I will get a map 2 and whatever else I can today, but I put about 100 miles a day on the car and have close to 15k miles in last 6 months with the jb4 and after initial testing, i have been in map 5 everyday unless I was trying to capture some different pulls/maps.
I will be happy to run whatever beta version or dev build you are working on and provide feedback
Default 01-29-2019, 12:49 PM
Sounds good, thanks! A good map2 log next.
Car: 2014 Ghibli
Default 01-29-2019, 08:07 PM
Here is a 2 and 5
Whooopasss Whooopasss is offline
Car: 2014 Maserati Ghibli SQ4
Default 02-02-2019, 12:15 PM
Hi Terry.. I am not sure which response is for me or wilcoxclay. So how was my logs? Am I good to go Map3?
pozo1478 pozo1478 is offline
Car: Maserati Ghibli S Q4 2015
Default Increased HP With JB4 - 02-09-2019, 01:00 PM
I am new!!! and I have the Maserati Ghibli S Q4 2015 (Stock 410 HP), What is the maximum HP that could be increased with JB4, using 91 oct, 93 oct and 98 oct ?
Default 02-09-2019, 01:15 PM
We have a dyno on our site but the gains when you refer to 98 octane, is that RON or RM2?
Default 02-11-2019, 09:36 AM
Is RON, please let me know, because I'm really interesting in your product!!!
Default 02-13-2019, 02:11 PM
Avoid 91 RON, use the 93ron or 98ron. The more octane the better. But I don't have specific dyno tests on your fuel. With the JB4 you can record logs and we can evaluate to help you ensure you're getting as much out of your tuning as you safely can.
Default 02-16-2019, 05:59 PM
Speaking of logs, again, how were my logs?
Default 02-16-2019, 09:54 PM
Sorry, missed the post!
Logs look good, I think I prefer map2 to map5 on your car for all around use. The turbo is so small the extra boost on map5 isn't adding a lot of power IMHO.
Default 02-17-2019, 02:42 AM
I am on map 2, is it safe to go map3.
Default 02-17-2019, 01:48 PM
I'd stay on map 2 for now.
Default 02-20-2019, 11:53 PM
Got it.. thank you!
Car: 2014 Ghibli
Default 02-26-2019, 08:37 AM
Here are some logs this morning and had a couple no boost ones
Default 02-26-2019, 10:56 AM
On the no boost logs, any codes coming up? What happens right before it stops making boost? I have a couple ideas as to what it might be.
Terry,, what is our target air\fuel at max boost please?
Car: 2014 Ghibli
Default 02-26-2019, 04:15 PM
No codes
Just accelerates like its not under load and wg is open and seems to kinda of stick when it gets to certain point and doesnt shift
Default 02-26-2019, 09:22 PM
Originally Posted by wilcoxclay
No codes
Does it come up more often when rolling off the gas, and then next run makes no boost?
Car: 2014 Ghibli
Default 02-27-2019, 07:05 AM
Could be, it does it repeatedly until you get back into cruising conditions and then wot will usually result in a boost building pull
Default 02-27-2019, 08:45 AM
OK drop me an email I have a firmware change you can test. Terry@burgertuning.com
Car: 2014 Ghibli
Default 02-27-2019, 05:27 PM
Here are two logs on map 2 with the new firmware
Default 02-27-2019, 06:53 PM
Email them to me, easier to manage one on one support that way.
Default 04-13-2019, 03:23 PM
Speedelement san jose did a dyno day. This is what we got for the Ghibli s q4 with jb4 set to map 2 and 91 oct.. no other mods
sport mode, manual 3rd gear pull.. mustang dyno
Default 04-13-2019, 03:38 PM
attached are the logs for the dyno run.
Default 04-13-2019, 06:47 PM
Not bad!
