bucketfoot bucketfoot is offline
Car: 2014 BMW X1 28i xDrive
Default N20 JB4 installed... kind of working, need some help - 04-21-2018, 05:36 PM
I recently picked up a used JB4 (N20 EWG) with bluetooth adapter for my 2014 X1.
Today I tired doing a test install with everything just hanging loose to make sure everything was working before doing the permanent installation.
I am able to connect with the mobile app and it allows me to change maps, but I am not getting a reading on any of the gauges.
Any help would be greatly appreciated!
Default 04-22-2018, 06:56 AM
Now I can't even get the app to connect to it. I guess it's time to remove it and try a fresh re-installation.
Default 04-22-2018, 09:39 AM
The X1 requires a special harness and firmware. CANbus attaches in the DME box, not the OBDII port, for example.
Default 04-22-2018, 10:03 AM
Sorry, I'm pretty unknowledgeable about just how the JB4 works.
Do I need the CANbus attachments if I have the bluetooth adapter. If so, is it possible to order the necessary harness?
I am assuming I can just download the X1 specific firmware...
Default 04-22-2018, 11:19 AM
IMHO better off selling that one and buying the right one for the X1.
Default 04-22-2018, 11:51 AM
Does the bluetooth adapter work with the X1 version?
I would definitely prefer that interface.
Default 04-22-2018, 03:28 PM
Yes, it's compatible.
Default 05-01-2018, 08:27 AM
Terry, I've picked up the correct JB4 for my X1. From what I have seen it gets connected somewhat differently than the other N20 versions, so is there a set of installation instructions available (I'm not seeing anything online)? Thanks
Default 05-01-2018, 08:57 AM
Same as E series N55 JB4.
Default 05-01-2018, 09:47 AM
Default 05-06-2018, 07:13 AM
Trying to install my JB4 this morning and I am having difficulty finding the boost solenoid connection. I think I'm looking in the correct spot (see attached picture).
Default 05-06-2018, 08:47 AM
OK, looked at the youtube video for the stage 1 and it looks like I do not use this connection since I have an EWG.
If that's incorrect let me know, but otherwise I'll proceed as if this is the case.
Default 05-06-2018, 09:28 AM
You are EWG so don't have a solenoid to connect to.
Default 05-06-2018, 10:12 AM
I've got everything connected up but I am not getting a bluetooth connection with my adapter.
I've checked the tap and I've got good voltage and if I go into my bluetooth settings on my phone while trying to connect with the app I can see the device briefly show up as connected. The connection drops after I get the "error getting handshake..." message.
Default 05-06-2018, 10:13 AM
Should I be able to also use the dash method to set things? I've tried hold the BC button and get nothing.
I think I'll re-clean and connect the canbus connections as I can't really think of anything else.
Default 05-06-2018, 10:25 AM
Don't know if this means anything, but everytime I try to connect with the app both turn signal arrows flash. The stop with the error message.
Default 05-06-2018, 04:03 PM
Figured it out... the App was set to Rev2. Changed it to Rev 3 and connected eight away
Default 05-25-2018, 03:46 PM
New issue that I figured I'd add to my original thread before creating a new one.
My map setting keeps getting reset to Map 4 from Map 1. Car is a stock E84 X1 with the N20.
Any suggestions on what I need to do or look for. Frankly the JB4 is worthless to me if it won't hold the map setting.
Kind of need to figure this out before I sell my Dinan Sport Tuner, because if I can't get this resolved I'll go back to it.
Default 05-26-2018, 01:41 PM
Here is a log that I saved where the mapping changed. I have no idea what to look for in this, but clearly the AFR drops can't be normal.
