Tyson413 Tyson413 is offline
Car: 2012 BMW 135i
Default New clutch solution. - 12-05-2017, 07:29 PM
Hi everyone. I have 2012 Bmw 135i 6MT with jb4,BMS intake,BMS charge pipe,VRSF c a t l e s s d o w n p i p e s. My stock clutch start to slip and I wanna update it with something that will hold the power that I have right now. Iím not planning for any other upgrades. I heard some people suggesting clutch for 550i but I wanna know more about it. Please tell me your experience,maybe some of you already went through this stage.
Thank you.
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 12-06-2017, 07:06 AM
It's an inexpensive direct fit option that drives like stock. Honestly if I put one in your car and didn't tell you, you wouldn't know. I've had no issues at all with it.
Car: 2012 BMW 135i
Default 12-06-2017, 07:29 AM
Thanks Kevin. Can you please tell me which one did you buy? Maybe you have a link for it? I just donít know is it for 550 e series or f series. And please tell me if I need to order anything else?(like bolts)
Thanks again.
durty sexn55 durty sexn55 is offline
Car: n55
Default 12-07-2017, 11:34 AM
Buy a spec stage 2 + or 3+
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
CT_Drifter's Avatar
CT_Drifter CT_Drifter is offline
Car: 14' F30 335i EWG N55
Default 12-07-2017, 02:19 PM
Spec is overkill with your mods.
Definitely go with 550i clutch, I ran it on my N54 e92 and now my N55 F30 with pure stage 2. It's oem quality and holds a ton of power. You may need to replace the OEM dual mass flywheel (DMF), the DMF is allowed .060 of axial play and 6 teeth of radial play. My F30 was well within spec at 50k miles.
The complete clutch kit id $370 from ecstuning
https://www.ecstuning.com/b-genuine-...n/21207603248/
Car: 2012 BMW 135i
Default 12-07-2017, 02:44 PM
Thank you all guys
