mike@x-ph.com mike@x-ph.com is offline
Car: 2007 e92 335
Talking Introducing Injen EVO1102 all new intake for the 2014+ BMW M3 & M4! - 08-21-2017, 06:46 PM
Injen is proud to be introducing the all new Evolution sealed cold air intake system for the 2015-2016 BMW M3/M4! This intake has been designed using the some of the most up-to-date engineering tools and techniques to produce a top notch kit. This intake system is on a whole new level, From the one-piece sealed housings that utilize the all new Injen Twist-lock System (Patent Pending) to securely attach the Injen SuperNano-Web Dry air filters in place. All the way down to premium hardware, Injen has put it all out there to give you, the customer one of the most killer intakes available.
Roto-molded Housings:
Both of the one-piece sealed housings utilize the all new Injen Twist-lock System (Patent Pending) to securely attach the SuperNano-Web Dry air filter in place which eliminates the use of unnecessary hardware and provides a simple installation that even your mom could do. Also to top it all off the housings sports our all new Midnight Edition Badge to give you that super clean look every time you pop the hood.
Roto-molded Intake Tubes:
This Evolution Air Intake System uses a couple of custom designed and dyno-tuned, intake tubes to produces huge power gains while retaining a clean and quality fit.
SuperNano-Web Dry Air Filters:
The SuperNano-Web Dry air filter is uniquely designed to work with the Injen Technology Twist-Lock System (Patent Pending). The Twist-Lock system has allowed our engineers to use one of the largest filters possible to increases air volume while keeping the installation process simple.
Quality Hardware:
Stainless Steel Band Clamps with inner protective liner and reinforced automotive grade silicone couplers are used to provide the most secure installation available.
Hassel-Free Installation:
Evolution cold air intakes that use the all new Twist-Lock System (Patent Pending) have been carefully designed to use fewer parts to provide the end user with one of the quickest and simplest installations available today.
Dyno Results:
After hours of design and dyno testing, This Evolution Air Intake system was putting down 22 additional horsepower and 27 lbs. of torque.
raichean raichean is offline
Car: BMW 435i 6MT
Default 09-30-2017, 04:35 PM
Looking great Mike.. love the red Injen charge ***** to btw!
Car: 2007 e92 335
Default 01-04-2018, 11:24 AM
Bump
Car: 2007 e92 335
Default 02-13-2018, 10:34 AM
Bump
eligard eligard is offline
Car: 2007 335i
Default 02-13-2018, 08:27 PM
Looks pretty good!
Car: 2007 e92 335
Default 03-15-2018, 09:42 AM
Bump
Car: 2007 e92 335
Default 04-30-2018, 12:53 PM
bump
Car: 2007 e92 335
Default 06-13-2018, 09:48 AM
bump
Car: 2007 e92 335
Default 07-26-2018, 09:56 AM
bump
Car: 2007 e92 335
Default 10-09-2018, 10:45 AM
bump
Car: 2007 e92 335
Default 11-13-2018, 10:58 AM
bump
Car: 2007 e92 335
Default 12-28-2018, 10:02 AM
bump
Car: 2007 e92 335
Default 02-04-2019, 09:04 AM
bump
Car: 2007 e92 335
Default 03-15-2019, 09:27 AM
bump
Car: 2007 e92 335
Default 04-22-2019, 08:01 AM
bump
Car: 2007 e92 335
Default 05-30-2019, 08:02 AM
bump
Car: 2007 e92 335
Default 07-13-2019, 10:02 AM
bump
