Default Fuel-It! Throttle Body Port Injection Testing - 05-26-2015, 11:14 AM
Sup guys, just got finished getting all the logs and pics sorted out for you all to see. We tested the Fuel-it! Throttle Body Port Injection solution on our STOCK TURBO N54 development car. I am saying solution because it is most definitely a solution. It surpassed my expectations in every way possible.
Lets start off with some pictures with the car apart and the TB/PI ready to be installed and put back together after it's done. It is a very clean and easy install, only took about an hour for me. Thanks again to @SteveAZ for this awesome kit, and thanks to @Terry@BMS for letting us test it out!
The car is an 07 e90 335i 6MT. It has, BMS DCI, 3" ********* **, VM Custom CP w/ Tial BOV, Walbro Inline 255, Jb4, BB e85 Flash by BMS. We just filled up from our local e85 station with full e85 in the tank. Along with new TB PI just installed. All runs were done in Map 7, in Mexico.
Here are two logs of the car WITHOUT the TB/PI working. You can see HPFP starts falling off mid-range, and picks back up near redline. LPFP is oscillating as well too, struggling to keep demand.
Log 1: No PI 1
Log 2 : No PI 2
Now this is with the ground attached to the hobbs switch. These two logs are with the TB/PI working now. You can see a VAST difference in smoothness of HPFP and LPFP. It was unreal to me how clean these logs looked with full e85. Take a look for yourself and be amazed. This is a real solution with real world testing and results, and we could not have been happier.
Log 1 : PI 1
Log 2 : PI 2
jwdominick's Avatar
jwdominick jwdominick is offline
Car: 08 535ix
Default 05-26-2015, 11:21 AM
nice
'08 535xi 6m, ACT 6 Puck Race Clutch / AR Design **'s / AFE Twin Power DCI / VTT Inlets / VRSF CP / TIAL BOV / Big Tom style IC / Fuel-It Stg2 LPFP / NGK 5992's @.022 / N20 T-Map / MHD Flash....100% e85 @24psi on stock snails!
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-26-2015, 11:47 AM
Damn nice!
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 05-26-2015, 12:39 PM
Your HPFP is better than most I have seen with straight E85; however, there is definitely a big improvement with the TB kit. I was surprised the FP_L smoothed out so much since it is still doing a lot of work. The kit definitely looks like another homerun from Fuel-it.
335is DCT
Default 05-26-2015, 05:02 PM
LOL...awesome, glad to see it's working well for you!
Thanks for the feedback!
Default 05-26-2015, 06:26 PM
I was thinking the same thing LOL. When I was reading the logs, I'm like crap are you sure you pulled the ground off the hobbs? Once we put the PI, it made a HUGE difference. Car is smooth and linear pull.
Anytime man! Great solution, and can't wait to test on some upgraded stock frame turbos!
amsnow440's Avatar
amsnow440 amsnow440 is offline
Default 05-26-2015, 07:34 PM
Excellent! Thanks for the detailed feedback and the before and after comparison. I will definitely be looking at this upon release. Your HPFP on 100% E85 looks like my HPFP on E55
2010 135i 6MT Jet Black | M-Sport | Michelin PSS 255/225 | Whiteline RSFB | Dinan Camber Plates | M3 Front Arms | JB4 G5 ISO w/MHD E85 Flash | E50 | BMS DCI | VRSF ** | VRSF CP w/ Tial | VRSF 7" FMIC | Fuel-It Stage 1 | NGK 5992 | TC Kline SA | VMR v710
Bump it up to 20psi and the stock HPFP doesn't stand a chance.
MDORPHN MDORPHN is offline
Car: 1M
Default 05-26-2015, 08:22 PM
Good stuff, Steve.
How have you verified equal distribution among the cylinders?
Neil
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 05-27-2015, 07:54 AM
any concern about the isolation AFR?
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Default 05-27-2015, 12:33 PM
Originally Posted by MDORPHN
Good stuff, Steve.
Neil
Any cylinder that gets less fuel, will also get less air, so while it may be down on power due to this equation, it won't affect the AFR's or octane levels.
Not sure what you mean by this.
Car: 09 E92 335i
Default 05-27-2015, 01:18 PM
Hopefully to see these kits in production soon!
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 05-27-2015, 01:25 PM
nice! interesting.. can someone explain why the lpfp seems to be more stable? I would think this would put more stress on the lpfp, but less on the hpfp
2009 335i e92 n54 | FBO | JB4 | e85 flash |
Car: 09 E92 335i
Default 05-27-2015, 01:42 PM
The low pressure fuel pressure sensor is located just few inches up stream from the fuel volume control valve of the HPFP. At higher load, the control valve will work very hard to supply the fuel that is needed for the HPFP, causing spikes and inconsistent fuel pressure in the low pressure system.
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 05-27-2015, 01:50 PM
there are (seemingly random) jumps and dips in AFR, mostly on bank 2.
I took the liberty to remove none related columns and rows.
Default 05-27-2015, 01:51 PM
The LPFP sensor is about 6's away from the HPFP's FCV, so that opening and closing to control flows will cause shock waves that the LPFP sensor reads.
A lot of things can play in to how active that FCV is such as adaptions, demand, LPFP pressures, etc. No question introducing supplementary injection reduces the volume demand on the HPFP, but it's turning the same number of revolutions and targeting the same pressures no matter what. We're just helping it achieve those when demand surpasses it's capabilities .
Default 05-27-2015, 02:16 PM
Hard to say for sure. I wouldn't really consider those to be large fluctuations and the reality is that we are introducing supplemental fuel that the DME doesn't have any control over. It is using the O2 sensors and the direct injection to obtain the target AFRs. So there can be some learning as well as I see some logs that are smoother than others both with TBI and without.
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 05-29-2015, 08:13 PM
I want one. Test, buy, whatever...I want one. 100% E85 all the way. Where do I sign?
2011 E92 N55 xDrive 6MT
DV135i's Avatar
DV135i DV135i is offline
Default 06-06-2015, 07:22 PM
+100000 I'm in all the way! Steve would you suggest upgrading to a stage 3 bucket before going with this? I'm over having to mix my gas every time I fill up lol
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR **'s~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 06-06-2015, 07:52 PM
same here let me know when are you going to start testing them/ selling them for n55 motors im down for one
2018 Individual Tanzanite Blue Competition M4
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 06-06-2015, 09:25 PM
If I wasn't upgrading my turbo's I would be all over this!
Jeffman's Avatar
Jeffman Jeffman is offline
Default 06-07-2015, 05:37 PM
As I asked over at the BB forum, how about a group buy with LPFP stage 2 bucket? This will be awesome for stocker turbo guys like me.
Default 06-07-2015, 08:07 PM
No, Stage 3 isn't needed.
DV135i's Avatar
Default 06-08-2015, 12:16 AM
How can I get ahold of this??? my car is now dialed in almost perfect except for the hpfp not being able to keep up all the time.
Car: 09 E92 335i
Default 06-10-2015, 10:40 PM
Got the car back together tonight and did some test runs. Nothing worth posting a log for at the moment, since I can only pump in 6 gal of e85 with a near 3/4 full tank of 93 still in the tank (so approx. e40 mix). But the kit is definitely working, fuel trim decrease significantly after the Hobbs switch turns on and my fp_h is reading higher than ever.
Will report back again once I get some full e85 in the tank.
