(#51)
Beetlejuice Beetlejuice is offline
Default 10-15-2013, 09:04 AM
Thank you very much, very helpful post!
DinoNac's Avatar
DinoNac DinoNac is offline
Car: F10 535xdrive
Default 10-15-2013, 10:26 AM
Originally Posted by az335iat
How to build the table or how to come up with the table values?
I assume the latter..... No.
If you do not have an idea of what boost curve you want to run then it is best not to be building your on boost curves.
If you do know what curve you want to run then just load those values into the table at the indicated RPM points and the JB4 builds the curve.
Note: If spraying, the meth adder value will be added to the Map 6 base curve.
I thought you said you were happy with your car and were going to quit playing with it.
JM $0.02 but if you keep on your present course your journey will not end well.
First Thank you for the info. I am very happy with the car and I'm only asking because Terry had suggested a custom map to potentially address the issue I was having in 3rd gear. If I'm not able to determine the cause, I thought that one option would be to lower the boost target in the low rpm range of 3rd gear, not looking to increase it. I agree with you about pushing the engine further not ending well. At this point I'm only trying to fine tune what I have, getting fuel/meth mixtures at levels that generate power and keep the engine running safely.
2011 F10 N55 xDrive MSport
BMS JB4 STG 2, BMS SCI, COBB FMIC, Dr. Euro CTLS ** AA Custom CP, MEISTERSCHAFT GTS
Triple Mishimoto 12" fans, with Dual Drerale Controllers
Flex Fuel Connectors, 45% E85
BMS 2.3 METH Kit, 30% tint, BMS HID Fogs
135iam 135iam is offline
Default 10-16-2013, 09:04 AM
Ability to run higher E85 mixes....if your fuel pumps are up to the task.
Higher AFR ratios which help the fuel pump problem.
For auto transmission cars higher load targets with quicker shifts and better timing post upshift when short shifting.
You could run a custom map 6 or just run map 7 and see how it looks.
Your not going to be leaving a lot on the table with a maxed out map 5.
Thanks AZ
my 135i is stock down to the paper filter with only the Jb4G5 ISO FIRMver 23 on map 5 with 45% E85. I am seeing a max of 16.7psi with stable low fuel pressure. I assumed this is about as good as it gets with the current setup.
FMIC and AR coated ********* going on over the winter.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 10-16-2013, 07:43 PM
Originally Posted by 135iam
Thanks AZ
Yes that is about all your going to get.... especially with E85 turning into E70.
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 01-20-2014, 12:26 PM
Hey Russell, for FP-L is that displayed in the csv as ffpid (N55 ISO 5.3)?
This value typically ranges from 55-70psi. If dropping below 50psi it indicates a problem
Is this range ideal all the time or only under WOT?
My log from yesterday is attached...avg ffpid is 29...thoughts?
Car: 2009 335i AT
Cool 01-20-2014, 05:53 PM
No. Sorry, FP L is not not logged for the N55.
FFpid is a calculation for the expected amount of PWM under high loads.
iuhutch's Avatar
Car: 2011 e92 335xi
Default 01-20-2014, 06:05 PM
So no way to tell if we're over running e85? You guys know of a n55 running or needing to run an inline?
Car: 2009 335i AT
Cool 01-20-2014, 06:17 PM
Not if you stay under 50% E85 during the summer.
iuhutch's Avatar
Car: 2011 e92 335xi
Default 01-20-2014, 07:09 PM
Are we maxed at that? Can I try 60-75% with inline?
Car: 2009 335i AT
Cool 01-21-2014, 10:27 AM
You can try anything you like.
You just have to live with the consequences.
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 01-22-2014, 06:19 PM
I don't want to purchase inline pump because of no ethanol selling in gas stations in Turkey. I just want to use ethanol when rolling in a Month to provide me a bit more power. So, should I use %30,%40 ethanol at map3 with factory fuel pump ? My car is 2007 335xi fbo+Rb turbos.
Thanks in advance.
rrodrig4 rrodrig4 is offline
Car: 2012 335xi n55
Default 04-03-2014, 07:59 AM
anyone tried running jb4 on top of GIAC stg1?
Im about to buy a car that already has the giac on it
any input would help,
thanks
Car: 2009 335i AT
Cool 04-03-2014, 08:10 AM
Go back to stock flash first. I believe you will not be able to save GIAC flash if you want to try other free flashes in the future.
NJz NJz is offline
Default 04-03-2014, 03:16 PM
am making a map 6 and plan on using meth as well. With the meth settings portion does it add boost in map 6 per the methenol settings tab boost additive section or does it just go by the boost requested on the map 6 column? Basically I want to know if it will request 18 psi or 24.5 on map 6 with a meth additive of 6.5?
NJz NJz is offline
Default 04-03-2014, 03:39 PM
I found the answer I was looking for here. Next question would be if I set the add to zero will meth still flow or do I have to set it to something low like 10 to make sure that meth flows. Thanks in advance.
Car: 2012 335xi n55
Default 04-08-2014, 10:00 AM
True, but I read in another tread that the back end flash doesn't work with the 2012 N55, any updates on this?
Car: 2009 335i AT
Cool 04-08-2014, 10:14 AM
Meth still flow with a zero adder.
Car: 2009 335i AT
Cool 04-08-2014, 10:15 AM
You will have to ask Terry.
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 04-09-2014, 10:06 AM
Russell your feed back it is excellent!!!
It is possible to post my logs from tonight to help me to check if my car runs ok?
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* ** - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
Car: 2009 335i AT
Cool 04-09-2014, 02:33 PM
Sure... just include log and start your own thread.
Alex!'s Avatar
Car: 135 I N54
Default 04-10-2014, 12:50 PM
http://www.n54tech.com/forums/showthread.php?t=24284
vibes81's Avatar
vibes81 vibes81 is offline
Car: bmw m135i
Default 04-12-2014, 01:21 AM
Hi Russell, I wish you well!
Could you have a look at my data and see what can be done to increase torque through the high rpms.
Thanks man.
http://www.n54tech.com/forums/showthread.php?t=24328
jaybmw335i jaybmw335i is offline
Car: bmw 335i
Default Logs for 335i 2008 - 05-20-2014, 07:53 AM
Hey guys, I have datalogs for my bmw and would love to get some help!
its a 2008 335i with COBB intercooler, Injen air intake, Borla performance exhaust, 3' high flow cats down pipe and a BOV
See attached. thanks!!
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-21-2014, 03:42 PM
Your logs are useless. Read the Stick "*** read me first ***", post csv in your own thread.
Car: bmw 335i
Default 05-24-2014, 01:54 PM
What makes them useless? which read me are you referring to ?
thanks
