(#51)
notabenex notabenex is offline
Car: MB W205 C250
Default 07-13-2019, 01:46 AM
So I went to friendly Mercedes dealer, they did xentry base diag and found no CEL s saved. probably my chinese obd erased them well..
I have screenshots with 0308 which should be misfire on cylinder 8. So replacing coils?
ezatnova's Avatar
ezatnova ezatnova is offline
Car: 335i Coupe
Default 07-13-2019, 05:19 AM
Originally Posted by notabenex
yes.
Not trying to give a smart answer, but honestly just asking, since youíve had issues have you gone back and double checked the entire install? Could a plug be swapped or something left unconnected perhaps?
ezatnova's Avatar
Car: 335i Coupe
Default 07-13-2019, 05:21 AM
Personally, I wouldnít replace any OEM parts if things run perfect on Map 0. The problem has to lie with the JB or itís connections Iíd think.
Car: MB W205 C250
Default 07-14-2019, 10:52 AM
Today on highway, map0, total loss of power, CEL car in neutral, shaking rattling.. was ready to tow it to dealer but after restart I went slowly home.. Going to dealer and also removing JB4.... this is the end of story
Default 07-14-2019, 03:08 PM
Send a photo of the JB4 control board when you're putting it back to stock so we can check that for any obvious indications of issue.
Car: MB W205 C250
Default 07-18-2019, 12:45 AM
So happy update, after towing the car to MB dealer they checked codes and realized that spark plugs were not correctly installed (previously went to my friend to do that....), so they took them out, cleaned surfaces, also did check of the coil packs and cleaned contacts on them.
Idle is now stable, everything is fine! No codes! So I have to say that blaming JB4 for that was not correct, but I wasnt expecting the shop to do that job so poorly..
I did more testing of JB4 in map 1+2, there is definitly much much less hesistation, but its still present, especially on map 2 in comfort mode. Its much better in sport+. So my question is, could there be a mechanism in comfort mode which is cutting power in the area 4000-4500 rpm on 4th gear to make everything more ''smooth''? Are you guys driving and using jb4 in comfort mode or after warmup you are switching to sport +?
Will post video soon.
video here c63 jb4 map2 spark plugs new on Vimeo
Terry what do you think?
Default 07-18-2019, 08:50 AM
^^^ That is awesome news man! I've been following your posts and thread for a while now and I'm glad it was solvable.
Car: MB W205 C250
Default 07-18-2019, 11:07 AM
yeeeah enjoying it C63 W205 JB4 map 2 on Vimeo
Default 07-18-2019, 11:28 AM
Wow, that thing pulls really hard! I had to look twice to make sure it's not MPH LOL.
Default 07-18-2019, 07:55 PM
Glad its been solved!
ezatnova's Avatar
Car: 335i Coupe
Default 07-18-2019, 10:50 PM
So the misfiring, shaking and CEL issue was corrected, but it cannot be good or normal that he has that obvious slipping and hesitation shown in his video. If that doesn’t happen on map 0, then there’s still something that needs to be looked into, correct?
Car: MB W205 C250
Default 07-19-2019, 07:40 AM
Originally Posted by ezatnova
So the misfiring, shaking and CEL issue was corrected, but it cannot be good or normal that he has that obvious slipping and hesitation shown in his video. If that doesnít happen on map 0, then thereís still something that needs to be looked into, correct?
It would be nice if Terry od Payam will help to solve this. thats correct
Default 07-19-2019, 06:49 PM
There isn't a JB4 log attached on map1 to look at on that front.
Car: MB W205 C250
Default 07-20-2019, 12:18 AM
Will do that tomorrow.
Car: MB W205 C250
Default 07-21-2019, 09:15 AM
Here is the log.. Map1 at first and then map2
Terry or Payam could you please check it? thanks
Default 07-22-2019, 08:01 PM
Sorry backed up on work today!
I don't see any strange behavior on map1. Did you notice anything? On map2 I do see an odd RPM movement while in high gear that seems like slippage of something in the drivetrain like maybe the torque converter unlocking and relocking. If it was trans spin I don't think it would recover so quickly and we'd see it more during high power post shift.
Car: MB W205 C250
Default 07-22-2019, 08:51 PM
I am doing these tests in comfort mode, maybe its cutting torque to make everything "easier to drive"? I dont think it happens in sport+, will test it today..Since my car is DD i drive in comfort 90% of the time.
Default 07-23-2019, 01:26 PM
Easy to test different things and isolate it, but that is possible.
Car: MB W205 C250
Default 07-25-2019, 12:34 AM
Well its behaving same way in sport+. I heard few users had problems with corrosion on PCB, but my issue is present since install so probably PCB is OK.
Any other things to try? Thanks
Default 07-25-2019, 08:33 AM
If you have check engine lights related to the specific sensors you've attached the JB4 to then that would point to a hardware problem. You don't.
Just keep it on map1 if that is working best for you at this point.
Car: MB W205 C250
Default 09-01-2019, 10:20 PM
probably coil pack is dead? CEL and rough idle, even now on map 0
Default 09-03-2019, 01:23 PM
Misfires are usually coils, injectors, or plugs. I've also seen O2 sensors go out causing similar issues on just one bank.
Car: MB W205 C250
Default 09-13-2019, 10:14 PM
I had fully functional 2017 C63, since I installed JB4 I had problems.. after few days first misfire then CEL's, rough idle, sometimes weird behavior of rpms.. it was not right since I installed it. Terry said change plugs to new one which I did and I have to say shop didnt make it well so they fixed it at the dealership... Car was still putting CEL's, start stop not working, loud start sometimes not present, it was just NOT RIGHT.
It ended up with car running like shi* pump, I was unable to drive so I had to tow the car to dealer ship where it spend 3days..they checked spark plugs, coil packs, injectors and even measured pressures in valve chambers.. when they out it together it was still not going well, but when they tried every piece separately problem was not present. so after two days they decided to remove jb4, reflashed engine software and car is running great.
All my problems started with JB4 install, all of then dismissed when it was removed.
Maybe I was just unlucky and my jb4 is faulty.. (I was one of the First in the beta and after received jb4 I got email from them that I have to repair the board.. so maybe board is wrong.. dealer think that maybe some of the connectors are wrong.
I have Brabus piggyback on my wife C300 and its behaving perfectly for 150000kms
So total cost for this "Experience" was 1300 for jb4 with taxes and shipping to EU, 200 for install, 500 for plugs and install (which was not necessary), and this final tow + 3days at dealership for 1200. So its 3200.. and now I have box with probably faulty unit which I am scared to sell to someone
ezatnova's Avatar
Car: 335i Coupe
Default 09-14-2019, 09:00 AM
Ugh. Maybe BMS should take your unit back and offer to test it on their car. 2 hours of pain in the ass for them to uninstall/install, but it would be the most thorough method of troubleshooting support, I feel like. Canít just swap the JB board in case itís your harness, but as a quick first step maybe they could just try that
Anyway, curious a) is that black foam thing in the box part of what came with your kit? B) why is there a purple wire hot glued to your board??
Car: MB W205 C250
Default 09-15-2019, 12:23 PM
Black foam is packaging from dealer who gave it to me in that
Purple wire I think is from BT module, need to check.
No reply from Terry or anyone from BMS, what to do now? Should I send the unit back? Can I get refund?
