(#101)
Default 02-16-2019, 10:22 PM
Originally Posted by sheharyar_rr
Any point in doing it if im on 94 octane pump gas? I have a dme flash
Not if also flashed, since the flash would have already cranked up the WGDC tables giving the JB4 plenty of extra room on it's targeting. In fact it might be you want to use the JB4 EWG connections to LOWER WGDC at some point.
sheharyar_rr sheharyar_rr is offline
Car: 2014 335i M sport
Default 02-16-2019, 10:34 PM
How do i go about getting this EWG jb4? i flashed the s63tu jb4 with the firmware you gave me. I guess i need to install it back
2018 BMW M550i
BMS JB4
1/4 mile 11.0 @ 125
Default 02-17-2019, 06:25 PM
New G series N63TU systems we ship have the connectors, best option is to upgrade to a new harness.
Default 03-27-2019, 06:32 PM
Noticed out G series N63TU has the JB4 installed on the passenger side, when the current harness is spaced out with a shorter OBDII to install on the driver side.
I don't have a car handy here. If anyone has time post a few install photos in the thread so I can update our guide until we can get our hands on our local M550 test car again.
Tsela_f80 Tsela_f80 is offline
Car: F80 M3
Default 03-28-2019, 11:12 AM
This was actually an issue with my JB4 when i installed they ended up have to extend the wires to even reach
Default 03-28-2019, 08:45 PM
Darn wish they had emailed us, you just place the box on driver side now.
Car: F80 M3
Default 03-29-2019, 08:04 AM
Auto Couture did email you. they would of put on the drivers side but weren't sure if there was a specific reason it needed to be on passenger side.
The Jb4 works fine, but the re-sale of the unit is out the window now since wires had to be extended which is pretty annoying.
Default 04-01-2019, 09:44 PM
If they had emailed us we'd tell them not to modify the unit and to place it on the driver side. But makes little difference. Shorten the wires again later next time you install/remove it if so inclined, or not.
HamAC_01 HamAC_01 is offline
Car: M550i
Default 04-02-2019, 05:48 AM
Yeah, i tried putting my jb4 on the passenger side lodged between the air filter housing and the side wall but it kept dropping down so right now i dont have the obdII connected. Im gonna figure out a way to get it to fit today and ill post some pics!
Default 04-02-2019, 08:48 AM
Check our F90 M5 JB4 install guide, it's the same basic engine bay.
Car: M550i
Default 04-02-2019, 04:49 PM
Pics for install - m550i jb4
Red lines- tmap
Blue - obdII
the ewg sensors are just ziptied to the brace and the jb4 box is ziptied to driver side brace.
Imgur: The magic of the Internet
Default 04-03-2019, 09:27 AM
Red lines- tmap
Photo of what your space looks like with brake booster cover removed? Should be able to zip-tie box there.
Car: M550i
Default 04-03-2019, 09:58 AM
It should fit under the brake booster cover however since i installed it with the short tmap plug going to the passenger side, i dont feel like taking the entire thing off just to put the jb4 under the brake booster cover lol. This setup will do lol
Default 04-03-2019, 10:09 AM
Ah OK, no worries.
Car: F80 M3
Default 04-10-2019, 09:22 AM
heres a 5th gear map 2 log from 2900ish RPM
Thoughts?
Default 04-10-2019, 02:17 PM
Thoughts?
Generally looks OK. Would probably response well to a little more octane.
Car: F80 M3
Default 04-10-2019, 02:23 PM
i ordered a Draggy today, i will try again with 100 Octane.
ill post results
Default 04-10-2019, 06:35 PM
Sounds like a plan!
Car: F80 M3
Default 04-16-2019, 07:48 AM
[IMG]
[/IMG][IMG][/IMG]
here a map 2 run on 93 Oct.
for the 1/4 run i had a crappy launch did 0-60 in about 4.5, was able to do 3.4s on other launches.
Default 04-16-2019, 09:09 AM
Not bad! Log of the 1/4 mile run to see how boost looks?
Car: F80 M3
Default 05-03-2019, 09:38 AM
Has anyone tested with all connections made?
BRICKYARD BRICKYARD is offline
Car: 2019 BMW M550i
Default 06-10-2019, 06:45 AM
Anyone have a ball park figure on what kind of horsepower/torque gain you get from the JB4 Map1 setting with stock parts from the 2019 M550i?
Default 06-10-2019, 08:42 AM
The gains are pretty substantial, but we don't have any dyno figures yet.
Maybe someone will chime in if they have one.
Default 06-10-2019, 04:11 PM
Even map1 is worth 40-50hp.
Default 06-11-2019, 09:29 AM
I noticed some G N63TU are using 2.5 bar TMAP sensors and others 3.5 bar TMAP sensors. So I'm going to have to adjust the firmware to auto detect it.
Would be helpful if G series N63TU cars could post logs in this thread so I can get a better feeling for which year cars are running which sensors.
