(#951)
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 04-22-2019, 07:47 AM
Originally Posted by rallyrafa
There's a problem to use MHD stage2 + JB4 map3 or any other map?
I like the linear response and xHP support of MHD stage 2... So far no problem at all.
+1 Same question here, I will be wanting to flash xHP soon.
2013 BMW 335xi F30 N55 PWG
Summer '20 install: Speedtech BW 8374/PI & Tune by Trebila
Default 04-22-2019, 07:48 AM
JB4 doesn't care what flash map you use, but I'd need to see a JB4 log for any specific tuning advice.
Default 04-22-2019, 08:03 AM
Cool, thank you.
rallyrafa rallyrafa is offline
Car: 535i GT 2011
Default 04-25-2019, 12:03 PM
Should i turn off jb4 BEF option? With mhd stacked?
2011 535i f07 custom pipe after turbo, VRSF CP, K&N CAI, E40+ BEF
Default 04-25-2019, 12:51 PM
You have to set JB4 in Future Use D to tell it you have a BEF, regardless of which BEF it is. As far as I know anyway.
Martin.328 Martin.328 is offline
Car: 16 328
Default 04-26-2019, 12:01 PM
Originally Posted by Yoandry
Doesn't dragy use Bluetooth too? How you going to connect 2 bt devices, jb4 and dragy to one phone, ain't gonna happen.
If u have an iphone no but us samsung guys can connect to multiple bt devices at once. Samsung>apple.
Btw terry i bought an mhd flash but i have issues running the jb4 and mhd ots e map at the same time. One issue is that the car keeps accelerating for a split second n i never hit target boost.
Car: 16 328
Default 04-26-2019, 12:03 PM
Mhd told me to uninstall jb4 complately but then i cant datalog.. i was running map 4
zookerjr5 zookerjr5 is offline
Car: 2012 335i F30
Default 05-01-2019, 07:22 PM
What map are people running with their BEF? What's the best one with the most power?
Car: guess...
Default 05-01-2019, 07:48 PM
Are you seriously asking this here and now, 39 pages deep? Millennial?
Car: guess...
Default 05-01-2019, 08:28 PM
Sorry, after dinner I realized I may have been a bit 'hangry' and slapped unprovoked.
Everyone's cars are different and have different tunes+upgrades. A bef maximizes the tune the best it can for those mods. The questions your asking will receive a full spectrum of answers as there's infinite mod combinations.
Knowing what you've read about already, what do YOU think the best bef would be?
Default 05-02-2019, 10:22 AM
For any tuning help on our BEF maps post a log here. You log via the JB4. MHD is just used to load our map and then unplugged from OBDII.
Car: 2012 335i F30
Default 05-02-2019, 07:08 PM
Not your fault I didn't give enough info. Reason I ask is because it seems my car if falling on it's face in higher rpm's but running better in map2 rather than map 5. I do not plan to ever run E85 so 93 octane from Costco is all I run ever.
Currently car mods are MHD BEF PWG3_Race, K&N Intake, ER ***-less down pipe, ER TIC Charge Pipe, ER Comp front mount IC, ER Charge pipe, MPE with an Exhaust dump before muffler.
I am beginning to think that the cars PWG is the problem and I need to replace BMW part # 11747626351. Due to the fact that the duty cycle is higher numbers in the higher RPM's. Here are two attached logs. Thanks for any help.
lazyninja87 lazyninja87 is offline
Car: 2012 F30 335i
Default 05-03-2019, 07:19 AM
Hi all... i applied the latest 8/2/18 map last year around October but still get the boost under target message. The update says:
1) Addressed false alarm under boost fault code in various map versions
Does anyone know if that update was made AFTER 8/2/18 in the file?
Kay-os Kay-os is offline
Car: BMW M235i
Default 05-03-2019, 07:42 AM
Anyone here flashed the cold start noise reduction option? Any issues?
I recall someone here experienced rough idling on starting engine. I wonder if this has been resolved?
2014 BMW M235i auto. JB4 & EWG connector + BEF (BMS EWG Race 10 map), 98 RON pump fuel (93 oct), BMS WMI kit (dual BM5 nozzles, 80% meth mix, boost additive 50, Scaling 60, min flow boost 6.5), GruppeM intake, ER CP, Forge BOV, Wagner Evo II competition intercooler, ER ******* **, eisenmann exhaust, quaife LSD.
Never2Low Never2Low is offline
Car: 2014 535i PWG
Default 05-03-2019, 08:02 AM
I have, no issues really. However, I am running E85 so she rarely likes to idle like butter when first started.
Default 05-03-2019, 08:18 AM
Some cars don't like the cold start delete for whatever reason, but it's easy to toggle it on and off during flash under options.
Car: BMW M235i
Default 05-05-2019, 01:33 AM
Thanks guys your reply. Iíll try out the cold start noise reduction tonight and will report back.
spammer's Avatar
spammer spammer is offline
Car: 435i
Default 05-05-2019, 07:55 PM
Thatís incorrect I use draggy and jb4 together all the time. Along with Spotify you can connect multiple BT devices on most any phone.
Car: BMW M235i
Default 05-06-2019, 07:52 PM
Tried out the cold start noise reduction option. So far so good! No rough idling or stutter. So much quieter on cold start now. Should have done this earlier. Lol
Bsbllfit7 Bsbllfit7 is offline
Car: 2013 535i
Default 05-20-2019, 02:03 PM
The problem is with the newest PWG firmware for the jb4. My car had the same issue and thought it was plugs or coils. I ended up downgrading the firmware to version 12 t2 and the issue resolved. Just to validate the issue I switched back to version 13 and the problem came back. Downgrade your JB4 firmware to version 12 t2 and youll be good to go!
Car: 2012 335i F30
Default 05-20-2019, 05:39 PM
Thanks for the info. I did end up buying the part and it didn't fix it. So I think doing the downgrade should fix it unfortunately. Was an easy install for the car having 115k on it. Also did the tensioner while I was at it. Thanks for letting me know a solution!
CC424 CC424 is offline
Car: 2014 535i M Sport
Default 05-28-2019, 06:51 PM
Iím on the pwg race 3 map with a bms filter, VRSF ********, and jb4 with mhd. Which map do you use for stage 2?
M235iHUSTLE M235iHUSTLE is offline
Car: M235i xDrive
Default 05-30-2019, 12:00 PM
Hey terry, I Just went FBO and MHD BEF.
Where would I send my logs to you for review?
Car: M235i xDrive
Default 05-30-2019, 12:04 PM
Attached:
Default 05-30-2019, 12:06 PM
What fuel? Something is odd with timing here.
