Stoolz Stoolz is offline
Car: 11 135i
Default 01-27-2019, 12:54 PM
Guys I'm running the Quaife lsd, is my back end strong enough for 600?
Default 01-27-2019, 08:59 PM
Worst case might need axles but it's probably OK... Never had any issues with our 2011 135i @ ~530whp launching on drag radials. Traction, that was another story. =/
keyap keyap is offline
Car: N55 135i
Default 02-16-2019, 01:50 AM
I think myself and Newguy had the same issue with the driveshaft. Probably due to how the PS2 delivers it's power as it wasn't at launch but was a result of wot from a rolling start in a higher gear.
I was 'experimenting' at 26psi when it happened.
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | Berk Race Full Exhaust | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
Car: 11 135i
Default 03-29-2019, 02:04 AM
Originally Posted by JacquesN55
I think its time for new motor.
I bought a 235, swapped it's 15k mile Engine into my car.
I still have the problem. This is crazy.
Car: 2011 N55 135DCT
Default 03-30-2019, 10:41 AM
Have you changed the engine harness and those stiffer mountings yet.
Default 03-30-2019, 10:43 AM
Ive decided to go PTE 6266 T4 twinscroll 0.84 turbine on my car. Doing new T4 Twinscroll manifold also.
Car: 11 135i
Default 03-30-2019, 02:35 PM
Yeah done all the harness sensors etc..
We just swapped the hpfp, fingers crossed.
Jagged a 2C01 code (never have before) so chasing that now.
