Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default B58 Map6 5 psi flat review and rail sensor code - 01-17-2019, 09:39 AM
Hi all,
It is cold here right now-30ish. Several WOTs with Map 6 at 5psi flat have been very good. However, I keep getting a code "119001 rail sensor short circuit+".
I did not get any at 4.5 flat.
I have changed FOL from 85 to 70, but have not had time to do WOT's at that setting. FF wire connections appear OK.
Please check the attached run. Comments and advise appreciated.
Thanks,
Alex
Default 01-17-2019, 09:57 AM
Log looks okay but yes, FOL at 85 is a bit high. Putting it down to 70 should do the trick.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 01-17-2019, 10:37 AM
Thanks. Will do.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 01-23-2019, 04:36 AM
FOL down to 70 and then 60. Still getting the same code. Suggestion? Explanation?
Thank you,
Alex
Turboh's Avatar
Car: 2017 BMW 340iX
Default 01-29-2019, 10:02 PM
Thank you,
Alex
FYI, the 60 FOL is working fine and no codes.
Thanks.
Default 01-30-2019, 10:23 AM
Thanks.
Ahh just saw this, yes usually lowering it will do it.
70 can trigger it cause it is really cold out now.
Glad you got it!
