(#1576)
Default 01-18-2019, 09:11 AM
Originally Posted by ravits
Hi Guys ,
I`m just switch from jb+ to Jb4 (Metal case with bluetooth module) today on my X3m40i
It`s seem like the jb4 doesnt seem to give any additional boost as compare to jb+ which is straightforward.
Tried map 1 & 2 so far.
Tried updated firmware to 11._test4.hex still the same.
Able advise , am using Oct 95 , stock air filter with jb4
Issit safe to switch to map 3 ?
Do you have any logs that we can look over?
ravits ravits is offline
Car: X3M40i
Default 01-18-2019, 09:54 AM
Hi ,
Pls take a look i have change to map 3 instead of suggested map 1 & 2 for stock setup
Car: X3M40i
Default New Jb4 with bluetooth module x3m40i user - 01-18-2019, 09:57 AM
Please take a look
Default 01-18-2019, 10:30 AM
I need better logs. Get me log on map 1 for now.
Start in 3rd or 4th gear from about 2k rpm till redline, make sure pedal is 100% for consistent data.
Car: X3M40i
Default 01-19-2019, 04:25 AM
As requested.
Car: X3M40i
Default 01-19-2019, 04:31 AM
As requested.
as request.
Car: X3M40i
Default 01-21-2019, 03:18 AM
Hi ,
Please find 1 more
Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default 01-21-2019, 05:50 AM
Make sure you have entered all the default values shown on the JB4 installation instructions. I had a similar problem and that did it for me. Map 2 is great at 93 and 3 should be really good for your octane.
For me, with 93 octane, map 6 at 5 psi flat seems best. Remember that timing is just as important as boost.
Enjoy
2017 340iX with M track handling package, 6 speed manual, BMS intake, and JB4 piggyback; EWG and FP wires; 93 octane; and fun with Honda S2000; Ninja Z1000.
Car: X3M40i
Default 01-21-2019, 08:51 AM
Hi ,
What you mean by default value i thought just plug & play select which map
Turboh's Avatar
Car: 2017 BMW 340iX
Default 01-21-2019, 11:10 AM
Sorry, I just looked at your runs and you have them....all set!
Turboh's Avatar
Car: 2017 BMW 340iX
Default 01-21-2019, 11:24 AM
Still, just glancing at the WOTs, you should run them as requested by Payem…..start at 2000, wide open to 6000+, in 3d only. Also, remember that depending on the map, auto adjust will take several runs to settle out.
n55pioneer n55pioneer is offline
Car: '11 135i Coupe
Default 01-22-2019, 09:47 AM
Can we still run jb4 as a pass through tune with CAN functions active? Or that's gone now that there is a Valet map?
Default 01-22-2019, 12:16 PM
You mean for flash tunes?
Car: '11 135i Coupe
Default 01-22-2019, 03:16 PM
To be able to log without jb4 intervention to stock dme tune?
Edit: I suppose that could be used for logging a flash tune also, and add jb4 functions like guage hijacking, etc., I guess you guys don't like that? Or it doesn't work?
Car: X3M40i
Default 01-24-2019, 07:08 AM
Hi ,
Any updates for my jb4 any issues what map should i run or cant run .
Car: '11 135i Coupe
Default 01-26-2019, 08:29 PM
No answer?
If anyone is wondering, it looks like on the test build map 0, jb4 will log the oem dme, but has no CAN functions like guage hijacking.
Has anyone tried build 9 with map 4? Will this allow full jb4 functions with oem dme tuning? Or I need to try it on my own to test? Lol?
BMW After BMW
Car: BMW M240i
Default 01-26-2019, 10:28 PM
No answer?
Firmware 9 Map 4 is an OEM tune with full JB4 functionality like logging and gauge support.
Firmware 11 Map 4 is a valet map with full JB4 functionality but reduced boost. You can log on Map 0 for baselining and benchmarking even without hijacks.
Car: '11 135i Coupe
Default 01-27-2019, 12:04 AM
Thanks MasterYous.
Rattmuff Rattmuff is offline
Car: Bmw 320i 2018
Default 01-29-2019, 04:12 AM
Running map 6 17psi flat boost but running high on afr 15-16 with maxout fueltrim at 50!
Being experimenting with diffrent firmware, lower psi, high FOL at 90....but nothing happens to AFR or fuel trim in map 6. Runs great with low afr in map 1, 2 and 3.
Do I need FF-wire?
Driving a Bmw 320i 2018(B48) with JB4 brought late 2018
Best regards// Rasmus
BMW After BMW
Car: BMW M240i
Default 01-29-2019, 08:59 AM
Do I need FF-wire?
BMS has essentially said two main things about the FF wire:
- FOL settings don't do a thing if you don't have the FF wire
- FF wire is for people doing more experimental things and analysis and is generally not needed for most setups
So you can evaluate. It's a low-cost/low-risk add-on, so you may spring for it anyway and see if it helps - it allows for adjustments to FOL which are helpful if you're going to be raising octane via Boostane, meth, or ethanol.
Car: X3M40i
Default New Jb4 with bluetooth module x3m40i user - 01-30-2019, 11:14 AM
Hi ,
Please find my log & advise which map should i run?
Will be going on a long trip can i turn on map 3 for a continues of 140km to 170km speed cruising for 4 hrs
File Type: csv 2019-01-31 00_13_58_Map-1 2019 2 to 6 gear.csv (20.6 KB, 60 views)
Default 01-30-2019, 12:25 PM
Looks okay, what fuel are you using? Go to map 2 and get a log first.
HIRRS-ZN's Avatar
HIRRS-ZN HIRRS-ZN is offline
Car: F30 320i
Default 01-31-2019, 12:28 AM
Hi Guys,
BMW re flashed my car with the latest BMW Software dated November 2018.
i have the jb4 and updated to V 11_Test4 and cannot clear error codes now.
Anyone else having this issue?
BMW F30 320i N20 - JB4 -EWG
BMW F30 320i B48 - JB4 - EWG - FF
Default 01-31-2019, 10:07 AM
Are you trying with ignition on, engine off? There was a change made we adjusted for awhile back.
HIRRS-ZN's Avatar
Car: F30 320i
Default 01-31-2019, 10:43 AM
I havenít tried that, but will do and let you know.
Iíve tried clearing the codes with the engine started only.
