DarrenR DarrenR is offline
Car: 118D
Default BMW E82 Drift/Track/Road 1M conversion - 04-03-2016, 12:12 AM
As I've now got a good start on my build i want to document it, Some of you may already be following the build either on my Facebook page www.facebook.com/DarrenRickabyDriftUK or in Performance BMW mag.
I really wanted to try and get the car ready for this years British Drift Championship but due to starting a new job and working away mon-fri Ive now come to the concussion that it will be finished when its finished as id rather not rush and get the car perfect.
A simple explanation....
I had my E30 V8 for over 4 years, loved every minute of it but it came to the point were 300bhp wasnt going to cut it anymore so it was either spend a few grand on turbo'ing the M60 or charge it like others have done, This would of done the job I'm sure but i needed a change in chassis and to try and challenge my driving style as well.
After selling the E30 i knew i wanted to build a E82 i was tinkering with the idea for a year before but they were just a little bit to expensive but over time they have came down to a sensible price. So in August (2015*edit*) i managed to buy a 118D E82 vandalised damaged full car which was perfect for me as i planned to change most panels anyway but under the white wrap the car wasn't to bad!
The Plan....
Bodywork- I toyed with many idea's, Rocket bunny arches, over fenders, custom arches but i want to go back to basics and use all genuine OEM 1M panels...... Unfortunately this being the most expensive way!
Engine- it was either a 1J/2J which would be awesome and easy, M50 turbo but i decided i wanted to try some new technology(may not work) so I've got myself a N54b30 (1M engine, 135 and 335 engine) these are good for 800whp from a stock engine (500bhp on stock twin turbos) We are going to go down the single turbo and are hoping for 650WHP. Ill be using a E46 320d 5 or 6 speed box
Chassis- Basically a genuine 1M is E9X M3 in disguise so I've already got most of my E9X running gear, rear subframe (with custom bits) a choice of 3.15 and a 3.85 m3 Diff, m3 power steering rack and from hubs (unless i run wisefab)
Huxley was already fitted a real tidy cage in the shell
Paint and Wheels - Unknown just yet
Thanks to everyone that has helped me so far with the car especially all the lads at Team Sunset.
So the pictures!
for some reason my photos are not working please see album here - for some reason its deleting all my pictures
My album is here - https://www.facebook.com/media/set/?...1&l=0220a04cd9
Car: 118D
Default 04-03-2016, 12:13 AM
Ive managed to get a touch more done on the shell, I'm working away mon-fri so i can only get one day a week to work on the car.
SchismX's Avatar
SchismX SchismX is offline
Car: '2010 135i
Default 04-03-2016, 01:02 AM
Looking forward to seeing more of this!
JB4 + Trebila custom flash / ********* *** / ER Chargepipe + Tial Q / VRSF FMIC / BMS DCI / BMS OCC / Alpina B3 flash
Car: 118D
Default 05-08-2016, 11:37 PM
Car: 118D
Default 05-17-2016, 12:44 PM
Ive managed to get the floor sealed, we have used a tintable UPOL raptor rather than stone chip this should be a bit more hard wearing. its awesome to finally see a colour on the car even if its just the underfloor.
i will still be putting a the base colour and lacquer over the top of this then i can start installing the fuel tank,coilovers and subframes then it can come off the spit for good and then we can finished the exhaust and manifold off. :D
F32Boost F32Boost is offline
Car: 2016 435i coupe
Default 05-17-2016, 05:34 PM
Awesome, holy chit man lotta work.
Props to you.... Great work!!!
Car: 118D
Default 05-23-2016, 08:51 AM
SOOOOO after a few weeks work the underfloor is now finished. 4L of upon raptor, 1L of base and 1L of lacquer i can now start to bolt bits up and get it off the spit!
Car: 118D
Default 05-29-2016, 04:16 AM
xIve start to get the custom E92 M3 subframe bolted up and for the first time in a few months its off the spit! The n54 engine is back in place and now to start finishing the single turbo manifold off.
Car: 118D
Default 07-25-2016, 05:40 AM
I've tacked me RHD manifold together! Finally! There's twin 38mm gates to go in yet
pajuis's Avatar
pajuis pajuis is offline
Default 07-25-2016, 09:58 AM
How did you buy the car in August of 2016?
2007 E90 Jet Black/ VRSF 7" FMIC/ VRSF CP/ VRSF lower CP/ HKS BOV/ VRSF **'s/ AFE Stage 2 CAI/ AFE Catback/ Dual Oil Coolers/ Fuel-it Stage 2 LPFP/ MMP inlets/ MMP outlets/ MMP Stage 3 Turbos/ MMP Port Injection/ BMS Catch Can/ RB PCV/ NGK's 5992 @ .018/ Alpina Flash/ MHD/ Split Second AIC6/ Wedge E50 Tuned/ 19" Niche M116 Wheels/ Toyo R888's & Toyo T1R's/ H&R Springs/ CSL Trunk/ M3 Rep front bumper with M3 ducts/ Cyba Scoops/ Custom headlights, Custom Tail Lights/ JVC HU with backup camera/ amp
Car: 118D
Default 07-25-2016, 01:13 PM
edited 2015
Car: 118D
Default 01-21-2017, 08:40 AM
For some reason I've been having a problem with the photos, should be ok from now on here is where I'm at with the car.
Ive still got a long way to go but looking back on the first few photos its also come along way.
Car: 118D
Default 07-21-2017, 12:55 AM
