Guymen Guymen is offline
Car: Cooper S
Lightbulb Check Engine - 05-09-2019, 01:45 AM
Hi
After installing the JB4 on my Cooper S i keep getting the Check engine light up (orange ) , i am using map 2 , car is running fine . i can reset it using the JB4 but it come back every time. Before the installation never had it, is it normal ? safe to keep on ?
Tnx
Car: B46 F56S
Default 05-09-2019, 05:13 AM
Does it do the same with map 1?
What is the code?
Car: Cooper S
Default 05-09-2019, 07:54 AM
didnt try map 2 yet so yes it happen with map 1 , didnt connect a code reader yet
Default 05-09-2019, 04:52 PM
You read codes via the JB4.
Car: Cooper S
Default 06-21-2019, 03:22 AM
finally had my hand on the OBD2 scanner ,the code is P12A4 " absolute pressure sensor intake manifold pressure too low" , again only happen when map 1 or 2 is activated , ok on default value . any idea
tnx
Default 06-21-2019, 12:04 PM
Next up lets see a JB4 log on map1.
Car: Cooper S
Default 06-21-2019, 08:09 PM
Tnx Terry , i guess i will need the BMS data cable to extract the log file ? i might be visiting the Simi valley are next month would it be possible to come over with the JB4 for checking it (without the Mini)? Tnx
Default 06-21-2019, 08:15 PM
Sure but if it's not coming up on map0 it won't be a hardware issue. Likely a software issue, so the data cable or blue tooth will let you read the code, adjust settings, do logs, etc, so we can resolve it.
Car: Cooper S
Default 06-21-2019, 08:18 PM
OK , will get the data cable , BTW do you see a problem keep on driving with the fault code ? the cars seems to run fine and it looks it happen when i start the car
Car: Cooper S
Default 06-22-2019, 01:08 AM
Looked all over and was not able to find the application s/w download for the USB cable connectivity , it is not where it used to be, any available link?
Tnx!
Default 06-22-2019, 02:17 PM
N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 laptop connection directions
Car: Cooper S
Default 06-22-2019, 08:27 PM
Tnx , got it !
Car: Cooper S
Default 06-23-2019, 12:04 PM
Made the cable myself and was able to connect to the JB4!!! my Firmware Ver is 58/8//5 , no idea how old and updated it is ? if not is there a place i can download the most updated one for the Cooper S 2.0L? tomorrow will try to do some runs and log the data , is there a particular place i should load it to ? Tnx!
Payam @ BMS Payam @ BMS is online now
Default 06-24-2019, 10:37 AM
Updated firmware will be on the bottom of the first post on this page:
MINI B38/B48 BMW X1/X2 JB4 - N54Tech.com - International Turbo Racing Discussion
You can upload your CSV file logs here so we can evaluate.
At the bottom of the reply box click go advance. Then you'll see a paperclip icon on the top. That's where you'll be able to attached the files.
Car: Cooper S
Default 06-28-2019, 01:24 AM
Tnx for all your help , new s/w is uploaded and seems to work well . about the check engine i notice when it come up it only when starting the car and never during drive (bot hard and soft drive ) it doesn't happen always but when it does it when i start the car.
i notice that my value of TMAP 3.5bar=1 , 4 bar =2 is set to 1 , is it right or should be 0?
is there a way to turn on and off the Fuel gage boost from the interface or on from the car itself? . i can share the CSV file but again the check engine is not coming on during that drive test, LMK
and again many tnx!
