smartsteve smartsteve is offline
Car: BMW 335Xi F30 N55 2013
Unhappy Error Code on JB4 - 05-15-2019, 07:03 AM
Car has gone into reduced power mode, I have attached screen shot.
Any guidance as to what is the cause and fix?
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 05-15-2019, 12:21 PM
Looks like the screenshot didn't attach.
Default SCREEN SHOT - 05-16-2019, 04:26 AM
size to big to upload, will type below:
133E10 VALVTRONIC SXYSTEM DISABLED TO FREUENT VERSTELLFEHLER
120408 REDUCED POWER MODE
160504 CRANKCASE VENTILATION HEATING CONTROL LINEBREAK
122108 BOV PLAUSIBILITY - INGNORE, TUNER CODE
1D2008 MAP THERMOSTAT, MECHANICAL JAMMED OPEN
Default 05-16-2019, 10:17 AM
Sounds like a VANOS fault? Sheered bolts?
Default 05-16-2019, 05:13 PM
Thank you, I will order Vanos, is that two that we need?
What is sheered bolts?
Default 05-16-2019, 10:42 PM
Sprocket bolts that hold the unit in place have been known to fail. 4 bolts.
There may even be a recall depending on your cars year
Default still codes - 06-02-2019, 07:26 PM
I got my car back changed the vanos, still the following codes, any help will be appreciated
Default 06-03-2019, 12:42 AM
Did you clear & those return?
Default 06-03-2019, 04:32 AM
sorry, do not follow your statement
Default 06-04-2019, 07:56 AM
I used MHD to reset adaptation for Vanos and throtle, error codes still appear.
What else is there to do?
Default 06-10-2019, 09:30 AM
I took the car to my garage, they scanned it and say they find no error codes.
Yet with JB4 and MHD the error codes above show?
Default 06-10-2019, 12:57 PM
update,
they said they found same error codes as I mentioned but they did not apply to year and make of my car
Default still codes - 06-10-2019, 04:59 PM
Update,
I decided to reflash BEF, after that it got rid off valvtronic error code.
Just left with error re: Crankcase Ventiliation Heating Control linebreak. Is this a vacuum leak or something else?
