(#4176)
Default 05-08-2019, 03:25 PM
Sure, just email us we can work something out.
djslug2000 djslug2000 is offline
Car: 2017 q60 ss
Default 05-11-2019, 02:15 PM
Is there a possibility of making the obd 2 wireless instead, avoiding running the cable through the firewall
Default 05-11-2019, 03:54 PM
We may offer an option like that in the future some day, for now it's OBDII cable only though.
TorchikRS TorchikRS is offline
Car: 2016 Infiniti Q50 RS400
Default Looking for a solution to a mysterious issue - 05-12-2019, 01:35 AM
What up guys! Iíve asked around on different forums and decided to ask here as well. I have a Ď16 red sport modded with HX, Intakes, L***, and tune. When I hit around 7lbs of boost my car begins to stutter and sound like it has rolling antilag. I have zero DTCs pop up and no possible signs that significantly point to the issue. Looking at my logs AFR looks good and Fuel pressure looks good. Has anyone else experience this issue? Any input would be helpful.
Thank you guys!
Car: Infiniti Q50 RS400
Default 05-12-2019, 09:52 AM
Thank you guys!
Put the stock tune back, get a Jb4 set to map 1. If it happens again let us know.
Boxy Boxy is offline
Car: 2018 Infiniti Q50 RS400
Default 05-12-2019, 11:31 AM
Hey Terry @ BMS, can you take a look at this log? in 5th gear car bogged down hard, and ign_1 shows 0 the entire way. Knocking? Wondering if I broke something. Boost response is all whack too.
Default 05-12-2019, 03:40 PM
Just a lot of boost request for an RS. What fuel mix?
Default 05-12-2019, 04:23 PM
This was on 93. Nothing to worry about yeah? Car was also pretty heatsoaked, CACT ended at 140 on that run
Car: q50
Default 05-13-2019, 09:14 AM
That timing graph looks like crap. I'd drop the boost down a couple PSI.
parsonsq50 parsonsq50 is offline
Car: Q50
Default 05-13-2019, 08:06 PM
car has started hesitating hard on acceleration when doing hwy pulls... Whats yalls thoughts on why?
18 base 3.0 AWD
map5
Fuel wires
Megan LDP
E30
Car: 2017 q60 ss
Default 05-13-2019, 09:47 PM
Hi Terry
What are my options in terms of maps for a 17 Q60 SS on 91 octane?
Am I able to request the jb4 to come shipped with map2 so I can avoid buying a data cable ?
Car: q50
Default 05-14-2019, 03:59 AM
18 base 3.0 AWD
map5
Fuel wires
Megan LDP
E30
Your fuel trims are just sitting pegged. At that boost, E30 isn't doing anything for you, but may be contributing to your hesitation.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 05-14-2019, 07:05 AM
18 base 3.0 AWD
map5
Fuel wires
Megan LDP
E30
Run that tank dry and try dropping to an E20-E25 mix, I have a feeling this car does not like E30 without an LPFP upgrade. I experienced the same hard hesitations and haven't gone back to E yet
2019 Q50 Luxe RWD *JB4 with Fuel Wires*BMS Intakes*AMS Downers*Frozen Boost 101*Megan Y Pipe*ADD W1 Oil Catch Can*HKS BOVs*
12.64 @113mph
0-60 4.46
buttons252 buttons252 is offline
Car: 18 Q50 Luxe AWD
Default 05-17-2019, 10:56 AM
Ive read a lot of fuel cut issues with E30 so i decided to run around E22 with ambients around 65F.
I am currently running map 7 without any issues. Going to do lowerDP this weekend and ease my way back to map 7.
Default 05-17-2019, 02:51 PM
Just be sure to check your logs and monitor timing advance, afr, and fuel pressure.
Speedy164's Avatar
Speedy164 Speedy164 is offline
Car: 2019 Infiniti Q50 sport AWD
Default 05-17-2019, 03:19 PM
Hey everyone and Terry and Ando, I just ordered the fuel wires, I'm not planning on running E85 but any ideas on what settings I should use? Meaning PSI per Rpm on Map 6? I will be installing HKS lower ***** next Friday. I know I have to datalog but perhaps a reference?
Default 05-19-2019, 10:24 AM
No special setting required. Just enable fuel wires under fud.0 once installed!
In terms of what JB4 map you run it;s realyl based on fuel and your factory tuning. RS or SS?
Speedy164's Avatar
Default 05-19-2019, 05:56 PM
I have a 2019 Infiniti Q50 SS and 93 octane, I am currently on Map 5 but tomorrow getting lower ***** installed HKS I moved up my installation appointment. I'm being told Map6 should put 7 psi here and 0 at 7,000 RPM. Wanted a starting point for Map6 reference, then I'll datalog and see how's it going and go higher if I could.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 05-19-2019, 07:16 PM
Why not try Map 7 and post your logs for everyone to comment on ?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
  • EcuTek Flash (In Work) Seb @ Specialty Z
g0t2bmiirii's Avatar
Default 05-19-2019, 08:16 PM
Hereís a run i did over the weekend on map 6 with +7.5 boost. 60 degrees, did about 120. Terry please check my log let me know if everything is good. Thanks
Speedy164's Avatar
Default 05-20-2019, 03:56 AM
Terry said ,Map7 is kill mode for E30 or race gas.
Car: q50
Default 05-20-2019, 07:02 AM
That log looks good!
Default 05-20-2019, 07:28 AM
Yeah i thought it looked good to me also. I gotta get a run when itís hotter outside cause of the extra boost i push
Car: q50
Default 05-20-2019, 08:49 AM
Stock mid pipe?
Default 05-20-2019, 10:50 PM
Stock mid pipe?
No itís aftermarket. Replaced the y-pipe. After the Y-Pipe i replaced the exhaust from top speed pro1. Which i believe included the midpipe all the way to the exhaust tips
