Stroker396's Avatar
Stroker396 Stroker396 is offline
Car: 535i
Default Not boosting to target??? - 09-01-2020, 10:12 AM
Ok so I started getting a little bit of boost. I went back and checked on the settings and it seemed a few were off so I fixed them for hybrid turbos. I did a quick run to see if anything has been fixed.
What I am seeing here is the engine is not reaching the target boost level it is matching the ECU PSI though?
Any ideas why this might be happening?
08 535i MT Blk. CP w/BOV, JB4, BEF, DCI, edited things delete, Inlets, 7" FMIC, SP exhaust, X Clutch, poly/delrin shifter bushings, Walbro 525, RB PCV, catch can, VRSF oulets, MMP Gen 1 Stg3, 3.5Tbar, 2 step, FSB WMI
Anti Lag up next.
On Hand: JB4 PI Controller
Default 09-01-2020, 01:52 PM
Is your tach set to 4/2?
Which map was this supposed to be in?
Stroker396's Avatar
Car: 535i
Default 09-01-2020, 02:19 PM
It was in map 1 when i started
Yes it is 4/2
Anti Lag up next.
Default 09-02-2020, 02:04 PM
Yes it is 4/2
Can i see another log, make sure you are in map 1
Stroker396's Avatar
Car: 535i
Default 09-05-2020, 08:42 AM
basically the same thing.
also the 2 step has never worked. is it maybe because it might be a G4 board
Anti Lag up next.
Default 09-05-2020, 10:40 AM
G4 board - 100% causing the issue
Need to upgrade to the g5
Stroker396's Avatar
Car: 535i
Default 09-12-2020, 03:32 PM
So installed a new G5 board today and no change. In fact I am pretty sure after looking at it that the old board was also a G5. Tried it with both firmware versions 14 and 15. Still no change.
This car went from overboosting a while back to no more than 5lbs.
Also the 2 step still does not work. I even double checked the white wire pin location and it is correct.
New log attached.
Anti Lag up next.
Stroker396's Avatar
Car: 535i
Default 09-13-2020, 08:31 AM
Ok so I was doing a lot of reading and sure enough it was a big boost leak.
Unfortunately the 2 Step still does not work though.
Anti Lag up next.
Stroker396's Avatar
Car: 535i
Default 09-13-2020, 06:58 PM
So as fast as I fixed it I broke it. It peaked at 17.2psi on map 2. I went out and did 2 tests runs from a dig (drag race) on the second run it bogged hard since no 2 step so no boost. and it shredded the belt. I found out at the end of the run and parked it. Hoping the front seal is intact.
Since the JB4 was not the issue is it possible to return it?
I am going to have other expenses
Anti Lag up next.
Default 09-15-2020, 09:59 AM
Email us:
Sales@burgertuning.com
Include your order #
