Stroker396's Avatar
Stroker396 Stroker396 is offline
Car: 535i
Default Genesis 2.0T surging at idle. not holding boost. log included - 04-26-2020, 08:32 PM
So my friends car is having an issue and until we solve it the JB4 is of no use.
Initially he had a check engine light and we were able to resolve it by replacing the BOV solenoid which was bad.
The issue now is that at idle, sometimes it will surge from about 450 to 750 rpm. It does not do it all the time.
We have added a BOV and when the engine is revved up it will close and then start popping open and closed.
We installed a set of 1 step colder plugs and gapped them at .024 to accommodate the JB4
I have included logs that show the boost bleed issue (all in map 0, logs in map 1 and 2 look similar). Has anyone encountered these issues? Any ideas what it could be?
08 535i MT Blk. CP w/BOV, JB4, BEF, DCI, edited things delete, Inlets, 7" FMIC, SP exhaust, X Clutch, poly/delrin shifter bushings, Walbro 525, RB PCV, catch can, VRSF oulets, MMP Gen 1 Stg3, 3.5Tbar, 2 step, FSB WMI
Anti Lag up next.
On Hand: JB4 PI Controller
