Stroker396's Avatar
Stroker396 Stroker396 is offline
Car: 535i
Default Runaway Revs? - 02-22-2020, 12:44 PM
Ok so good news. I replaced the PCV Valve and reset the ECU and now I do not get the neck snap at 3000 or the surging above 3K (needs more drive time to verify)
So wondering sometimes I turn around an give it some gas and the revs just run away. It does not feel like a tire is spinning as even if I shift gears it continues. I am wondering if it is the clutch slipping or what is causing it.
The new clutch and flywheel go in soon so I guess I will see. I moved the gear and speed next to the RPM so try and see.
But what do you think?
08 535i MT Blk. CP w/BOV, JB4, BEF, DCI, edited things delete, Inlets, 7" FMIC, SP exhaust, X Clutch, poly/delrin shifter bushings, Walbro 525, RB PCV, catch can, VRSF oulets, MMP Gen 1 Stg3, 3.5Tbar, 2 step, FSB WMI
Anti Lag up next.
On Hand: JB4 PI Controller
Default 02-22-2020, 02:47 PM
Based on that description, it sounds like slipping clutch. It spins, and then the clutch grabs when it can / with what’s left
Stroker396's Avatar
Car: 535i
Default 02-22-2020, 03:06 PM
Well weather is supposed to be nice tomorrow maybe I will get motivated and swap it.
I am having trouble searching for this answer. If I want to add an ethanol sensor and connect it to the JB4 do I need the whole bluetooth and app? Is there just a straight wire harness. I can do math and figure the proportion to add but I would like the JB4 to know exact.
I got a map 4 when I did a 1/4 pull in 4th gear I think. I may have hit redline. I was not logging at the time.
Anti Lag up next.
Default 02-22-2020, 03:54 PM
You. CAn do either- fuel it app or JB4 mobile
Stroker396's Avatar
Car: 535i
Default 02-22-2020, 03:58 PM
So no way to tap right into the JB4 with a wire harness. Bluetooth is needed.
Anti Lag up next.
Default 02-24-2020, 07:41 AM
Correct
JB4 has the virtual sensor feature, works well, but analyzer / Bluetooth is the most accurate
