itscuzimmaturk itscuzimmaturk is offline
Car: 08 335i e93
Default 2 step jb4 g5 - 03-14-2016, 07:36 AM
Hey guys my jb4 g5 comes in with the 2 step wiring, how do i wire it? Is it plug and play?
Default 03-14-2016, 07:39 AM
Read the 2step install guide.
Car: 08 335i e93
Default 03-14-2016, 08:32 AM
I couldnt find it, got a link?
alvinhobh alvinhobh is offline
Car: 07 BMW 335i Coupe
Default 03-14-2016, 08:49 AM
http://www.n54tech.com/flash_files/n54_nls_install.pdf
or ...
http://lmgtfy.com/?q=jb4+2+step+install
07 335i e92 - money pit
Car: 08 335i e93
Default 03-14-2016, 09:22 AM
It says it requires a bmw usb cable, where do i get one of that from
BigTwigg's Avatar
BigTwigg BigTwigg is offline
Car: 08 335i MT
Default 03-14-2016, 09:27 AM
Originally Posted by alvinhobh
08 335i MT, JB4, MHD, ***, ER Comp. FMIC, ER Charge Pipe, Forge DVs. Custom Alcantara/ Napa Steering Wheel. RB inlets (when I get time)
-Save the Manuals-
BigTwigg's Avatar
Car: 08 335i MT
Default 03-14-2016, 09:28 AM
I just ordred mine from www.BimmerSoftware.com
-Save the Manuals-
http://www.burgertuning.com/USB_Cable_Extension.html
But I happen to have one for sale, with the extension USB cable. If you are interested, PM me.
BigTwigg's Avatar
Car: 08 335i MT
Default 03-14-2016, 09:34 AM
^Go with that one.^
The one I ordered was for MHD (OBDII Plug)
-Save the Manuals-
Car: 08 335i e93
Default 03-14-2016, 03:41 PM
Does the actual usb end stay open?
Default 03-14-2016, 04:04 PM
The BMS USB is used mainly to perform datalogs with the JB4. You can monitor the car with the BMS software, and change settings.
The end which connects to the actual JB4 is a VGA connector, where you can connect the 2 step relay connectors by simply removing the plastic cover. The other end is a male USB connector, which is used to connect directly to your laptop, or tablet by using an OTG connector.
str8shot str8shot is offline
Car: N54 135i
Default 03-14-2016, 07:58 PM
It's not a vga connector, it's a db 9 serial plug.
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
Thumbs up 03-15-2016, 05:49 AM
^^ That's good to know. Thanks! =]
