Mvaccarelli Mvaccarelli is offline
Car: 2012 335is
Default 335is FBO inlets stage 2 LPFP map 6 20psi - 08-21-2018, 09:27 PM
map 6 log at 20psi looks good to me. running around E60 mix. I'm maxing out my tmap sensor at 20psi, going to get the 3.5 to run higher boost. what do you think the max boost I could run on these stock twins on my setup without blowing them up:]
File Type: csv 2018-08-20 23_27_17 new map 6 20 psi.csv (7.4 KB, 271 views)
lucas lucas is offline
Car: 135I
Default 08-22-2018, 04:45 AM
Hola...buena pregunta también quiero saberlo.Que intercooler tenes de que medida?.gracias
Car: 2012 335is
Default 08-22-2018, 08:04 PM
Bump can someone look at my log?
Car: 2012 335is
Default 08-22-2018, 08:05 PM
I honestly bought the car with the aftermarket intercooler already on I haven’t looked into what brand it is
Default 08-22-2018, 10:12 PM
Overall doesn’t look too bad.
Can try upping boost a little mid range once you get then n20 sensor
Car: 135I
Default 08-23-2018, 02:52 AM
Hola.rango medio 22 psi para turbo stock estaría bien ?.gracias
Default 08-24-2018, 08:00 PM
No habla espanol... lo siento
Car: 135I
Default 08-24-2018, 08:38 PM
hello, if the stock turbos can go well in 22 psi mid range?. The vrsf intercooler of 7 3d will be fine for stock turbos, it does not lag.
Default 08-26-2018, 10:35 PM
I’ve seen many logs of stock turbos in the mid range going 22+ psi, up top towards redline they just can’t hold boost.
In regards to intercoolers w. Stock turbos, I prefer the Bms / Phoenix 7.5 race option to any 7in
Car: 135I
Default 08-27-2018, 05:42 PM
hi dave.Many thanks for your advice!
Default 08-28-2018, 09:28 PM
No problem bud
