Stroker396's Avatar
Stroker396 Stroker396 is offline
Car: 535i
Default slow boost and maxes out - 05-23-2021, 05:53 PM
Ok so I have had boost leaks wondering if it is the same again. but it does not seem the same.
I recently replaced the water pump and it was dead from the get go. On the first drive it felt great but then wanted to overheat. parked it.
I replaced it...Again I did end up kinking the wastegate vacuum line witch I fixed and yet the boost builds slowly and then maxes out at just over 12.
Any ideas?
08 535i MT Blk. CP w/BOV, JB4, BEF, DCI, edited things delete, Inlets, 7" FMIC, SP exhaust, X Clutch, poly/delrin shifter bushings, Walbro 525, RB PCV, catch can, VRSF oulets, MMP Gen 1 Stg3, 3.5Tbar, 2 step, FSB WMI
Anti Lag up next.
On Hand: JB4 PI Controller
xargentum xargentum is offline
Car: E93 335i
Default 05-24-2021, 10:31 AM
Hello, I have the same problem, maybe you found the cure ?
Default 05-24-2021, 11:50 AM
Your FF and wastegate duty cycle are completely maxed out.
Car: E93 335i
Default 05-25-2021, 02:42 AM
Solution to this problem? :/
Or maybe its the boost leak ?
Default 05-25-2021, 10:16 AM
It's likely a boost leak or other hardware issue.
Car: E93 335i
Default 06-02-2021, 12:16 AM
My problem was a boost leak, between hose and intercooler
Default 06-02-2021, 10:48 AM
